Door Seal & Gutter
Started by spot1, November 10, 2014, 08:21:48 PM
Our top door seal leaks occasionally during heavy rain. Our 2010 CampLite 11 door has square corners and it looks like later model CampLite TTs have round corners, probably less likely to leak.  This door did not have a gutter above it, so installed a piece of aluminum angle to deflect water and probably will install some type of gutter when I find something suitable. Had awning removed during photos.
The original door seal size installed:
EPDM Black Rubber Bulb Seal Dome Shaped 5/8" wide & 3/8" tall McMaster-Carr Part # 93085K14 for $0.81 per foot
Decided to use the original sized bulb seals around the hinges where there's less air gap compared to non hinge areas. Purchased larger
bulb seal for the non-hinge areas.
Larger Seal:
EPDM Black Rubber Bulb Seal Dome Shaped 3/4" wide & 17/32" tall McMaster-Carr Part # 93085K68 for $1.00 per foot
Original seal on left and larger seal installed on right:
[a href="http://s657.photobucket.com/user/vstromklr/media/2013/2014/IMG_5242_zps613d260e.jpg.html"]
[img style="max-width:100%;" src="http://i657.photobucket.com/albums/uu299/vstromklr/2013/2014/IMG_5243_zpsa6235ee7.jpg"][/a]
[a href="http://s657.photobucket.com/user/vstromklr/media/2013/2014/IMG_5244_zps3ad22fab.jpg.html"]
[img style="max-width:100%;" src="http://i657.photobucket.com/albums/uu299/vstromklr/2013/2014/IMG_5226_zpsf3b0eba9.jpg"][/a]
Angle installed above door should have enough room for a small gutter, probably black rubber angle or aluminum angle with adhesive on one side:
[a href="http://s657.photobucket.com/user/vstromklr/media/2013/2014/IMG_5224_zpsfa4a94b7.jpg.html"]
[img style="max-width:100%;" src="http://i657.photobucket.com/albums/uu299/vstromklr/2013/2014/IMG_5224_zpsfa4a94b7.jpg"][/a]
Somewhere, Tinkerin' Techie is furiously snapping pencils in half out of rage. Mechanical pencils. The maker gauntlet has been thrown down !
It's fun building & modifying stuff. There's a large concentration of tech folks here and a great resource!
Will be camping tomorrow!!!!!!!!
[quote timestamp="1415680315" source="/post/4989/thread" author="@exploringcarolina"]
[/quote]Show off!
[quote source="/post/5011/thread" timestamp="1415754900" author="@paul"][quote source="/post/4989/thread" timestamp="1415680315" author="@exploringcarolina"]
[/quote]Show off!
This link has some photos from the trip!
Hope to finish the gutter project tomorrow!
livinlite.proboards.com/thread/638/time-camping-trip?page=1&scrollTo=5027
Finished the gutter installation. Purchased 1/2"X1/2"X1/16" thick aluminum angle and attached it with three self tapping metal screws. Sealed between the angles with silicone adhesive/sealant.
[a href="http://s657.photobucket.com/user/vstromklr/media/2013/2014/IMG_5311_zps387e5bbb.jpg.html"]
[img style="max-width:100%;" src="http://i657.photobucket.com/albums/uu299/vstromklr/2013/2014/IMG_5311_zps387e5bbb.jpg"][/a]
[a href="http://s657.photobucket.com/user/vstromklr/media/2013/2014/IMG_5308_zps99bf5063.jpg.html"]
[font size="3"]Good job, Bill. Problem solved.
Charlie, Thanks!!!!
It supposed to rain here Monday, so will get to test it since I'm going to leave the awning removed for a while!
[quote source="/post/4984/thread" timestamp="1415675326" author="@pinstriper"]Somewhere, Tinkerin' Techie is furiously snapping pencils in half out of rage. Mechanical pencils. The maker gauntlet has been thrown down ![/quote]I think it's awesome. The more tinkering the better  :)
You're right on the mechanical pencil though... I've got my Rotring 800 in my pocket at all times.
Thanks!!!!
That's one of the thing I like about camping, there's always things to improve and "tinker" on!
Where I retired from we used to do mechanical, electrical, hydraulic, and pneumatic R&D & manufacturing.
This forum's members are a great information resource!
