21BHS Battery Drain
Started by drake, June 13, 2016, 12:07:09 AM
drake
Our new trailer sat for a couple weeks with nothing switched on, but today I found the battery dead.
I realize there are a few small drains, but is this normal?
Thinking about installing a cutoff switch if this is a regular issue.
The CO and LPG detectors can draw a few tenths of an amp. Over a two week period that is enough to flatten the batteries. I am lazy and simple, so I just disconnect the positive leads to the battery. Or you can install a switch.
bobbie56
Yup, I second that.
I too found the "dead battery" and installed a cut off switch to disconnect the battery.
drake
