USB Charger...
Started by peislander, May 27, 2016, 06:54:05 AM
My small but mighty 2013 Camplite CL11FDB did not come with a usb charger. It did however come with a 12v outlet. (I'm old enough that to me it is a cigarette lighter outlet). On amazon I found an attractive little usb charger that seems perfect for the trailer. I particularly like that it features machined anodized aluminum -- perfect for an aluminum trailer. When I received it from amazon I was impressed with how well made it is.
>> [a href="http://www.amazon.com/Car-Charger-iCASEIT-Technology-Motorola/dp/B00UTXJP2C/ref=sr_1_3?ie=UTF8&qid=1464341788&sr=8-3&keywords=icaseit+4.8a%2F24w"]iCASEIT 4.8A Dual USB Car Charger[/a] << Input: 12v ~ 24v; Output: two 5v 2.4A ports. Output of 24 watts through two ports lets you charge two tablets, smartphones or other devices simultaneously and at full speed.
Intelligent circuit design protects against over-heating, over-currents, over charging and short circuit; Charging stops when battery is full.
 Intelligent technology equipped on all ports to identify each attached device & provide the highest recharging power that the devices can adapt to.
[img style="max-width:100%;" style="" src="http://s33.postimg.org/4jdpd329r/81_G5_rc_EMh_L_SL1500.jpg"]
Here's a pic of it in action in the small but mighty CL11FDB. It incorporates a blue led "feature". Sorry - a little blurry...
[img style="" style="max-width:100%;" src="http://s33.postimg.org/5a7fwori7/IMG_2105.jpg"]
looks like a small shelf may be in order
hey pe...if you want to keep with the aluminum decor...i found this small shelf on amazon as i needed one close to my usb outlet as well.  dont expect them to provide any mounting holes or hardware.  fortunately i was able to find a horizontal stud to mount it to.  i also added the hooks to the bottom for keys
That shelf is very attractive & your hooks are add even more functionality. Is the logo stuck on (ie removable)?
Quote from: @peislander" source="/post/21643/thread" timestamp="1464449672That shelf is very attractive & your hooks are add even more functionality. Is the logo stuck on (ie removable)?
Iirc it is held on with 2 small rivets.  Easy enough to remove, but you would be stuck with 2 small holes
