Charging the battery
Started by pjcd, August 16, 2015, 08:06:44 PM
pjcd
When I'm hooked up to street power, does the converter charge the battery? I plugged in the trailer and the power level indicator is registering 3/4, (same as when it wasn't hooked up). My old trailer, when hooked up would register full.
[font size="3"]The converter should charge the battery when hooked to shore power. Make sure all circuit breakers are on. Verify microwave or AC work. The 4 Led status panel is notoriously unreliable, but it should change when you connect shore power. The best way is to use a digital voltmeter right at the battery terminals. It should show greater than 13 volts if charging. If the microwave/AC work and the battery reads less than 13 volts check the battery connections and the battery reverse protection fuses. These fuses will be blown if the battery was ever connected backwards, even for a second.
pjcd
Thanks,,,,I'll check it out in the morning
