Size matters.....
Started by shovelhead, July 22, 2015, 01:04:46 PM
Open to a response from anyone not just LL.  Two questions.
Does LL make a toy hauler that I can haul my Can Am Commander side by side   11' x 6' x 6' ?
If there is a model can it be hauls by my 2011 Dodge RAM 1500 4X4 towing package HEMI engine ?
billmoore
From LivinLite website:
8.5x24 QUICKSILVER VRV TOY HAULER
Between WW: 78.5"
Approx Garage Dimensions:
To Optional Refer - 14'
GVWR: 8,000 lbs.
Load Capacity: *3,005 lbs.
Seems to me like that might work - you'll have 6.5 inches to spare between the wheel wells, and 3 ft to spare in garage length. One thing I'm not sure on is height. The load doors on the toy haulers are pretty close to the full ceiling height, which if I remember right is about 6'4".
Where you might get into trouble is GVWR with a 3000 lb load capacity. Water, propane and battery will use up about 500 lbs of that, and you can probably figure on another couple hundred pounds in options since the spec weights are for a stripped model. So you may only have somewhere in the range of 2000-2300 lbs of cargo carrying capacity. How much does the Can Am weigh?
Also, what is the rated tow capacity of your Ram, and can your Ram's payload capacity handle around 800 lbs of tongue weight?
dh50
[quote source="/post/13460/thread" timestamp="1437581086" author="@shovelhead"]Open to a response from anyone not just LL.  Two questions.
[/quote]Tell you what, Shovelhead, if you bring your Can Am Commander down to Central Florida, you can drive it onto our toy hauler and see if it fits for yourself.  :)
Knowing you won't do this, I will point my Hubby to your post for his feedback.
dh50
Your Commander will fit in a VRV or Axxess 24 ft. toy hauler. Our Axxess is 26 ft, has a 4600 lb cargo capacity, and GVWR of 10,000 lbs. Your Ram 4x4 Hemi should handle the towing, as long as it's tow rating is around 10K lbs.
You'll need a good WD hitch and electronic brake controller to keep things under control.
Regarding tongue weight: With our 2014 Ram, we put all our gear in the trailer, so only people ride in the truck, has worked well so far. With a half-ton truck pulling a 20+ ft enclosed load, don't try to keep up with the heavy duty pickups on the interstates. With our Ecodiesel, I cruise at around 60 mph, feels right with our rig.
Really pleased with the LL. Would not have been able to haul a conventional trailer this size without the weight savings LL offers.
Things may get dicey as depending on how far you can/have to pull into the trailer the balance will change a lot, which will affect the tongue weight. When you figure that out, you'll want some sort of guide to be lined up exactly (6.5" side to side is 3" margin on each side, so this fit will be tight) and also know when you are in the correct depth both to close the door and have the balance point where you need it, which can only be established empirically.
Found LivinLite ToyHaulers for sale @ Boat N RV starting @ $29,999. They have other LivinLite campers in this link, too. Two pages. Purchased my Mighty 11 from them new for $9,999.
http://www.boatnrv.com/default.asp?page=xNewInventory#page=xNewInventory&make=livinlite&d=on&t=new
I looked at a number of toy haulers.  Only one word comes to mind "Spartan"   I've had friends say my 21RBS was Spartan. (LOL)  I'll probably stick with my 21RBS for now and continue to use the side x side with my standard trailer.  I use the side X side at our hunting camp more then anywhere.  I dont do mudding, trail riding.
[quote source="/post/13581/thread" timestamp="1437768489" author="Steve Pro"][div][/div]I fit a Yamaha Viking and a Yamaha grizzly in my 8x22 VRV.  Pull with a ram 2500.  [/quote]Would you pull it with a HEMI 1500?
