Tire pressure for off road package?
Started by subaruwx, April 14, 2014, 07:42:14 PM
subaruwx
I have a QS10 with the off road package, including the 15in tires (LT235/75R15). I found lots of references for 80psi as the inflate pressure for the standard 12in tires, but what's the right pressure for the bigger tires?
Im im currently running 50psi, but that seems a bit high for a tire this size. My friend has a small truck with these same tires running 35 psi.  Any guidance from owners or the factory?
subaruwx
Follow up on this - note that the plate on the trailer says 80psi - clearly meant for the standard tires not the 15in radius tires.   I've only got 2000 miles on the trailer, so I can't really see any tread wear pattern that might suggest over- or under- inflation.
For ST tires you inflate them to the max PSI stated on the sidewall (in my case, 50 psi).  I assume it would be the same for LT tires, but this is a good question to confirm.  I don't think 35 psi is what you need.
