LivinLite camper composite floor question
Started by spot1, November 14, 2015, 10:58:48 AM
This is probably old news, but new to me.
Has LivinLite already started installing composite floors and which campers will have it?
Quotes from the Truck Camper Magazine article by Ryan Spencer, LivinLite General Manager:
"The new composite floors are vacuum bond laminated with block foam, aluminum framing, and two layers of Azdel; one on the top, and one on the bottom. The result is a lighter, better insulated, and more cost efficient floor that doesn't compromise strength. Nothing was lost with the new composite floors. It's all gain."
"There are a few more changes. The ceiling board is now a different color of Azdel. There's also an extra layer of Azdel in the walls, as standard, for improved insulation. Another standard is the fully-enclosed, insulated, and heated underbelly.
On previous CampLite units, the bottom was often open with exposed holding tanks. Now there's a covering across the bottom with insulation. We also added a heat duct that runs from the furnace into the basement. All units with tanks will now have heated basements."
http://www.truckcampermagazine.com/news/tcm-exclusive-2016-camplite-announcements
Thanks for your reply in advance!
pjcd
I've had trailers with the bonded floors,,,, not impressed with them, in fact one of the reason I bought a CL was the all aluminum construction, (including the floor). It seems the mission is changing, wood cabinets, bonded floors and who knows what else, CL is becoming no better then the standard, run of the mill RV.
I plan to keep my current CL for a long time so the changes doesn't really affect me right now but hopefully when I decide to upgrade it will be better and not worst than what I have right now!
christianm
Hi there!
The composite flooring is used [font color="#2119e6"]JUST [/font]in the Truck Campers, not any of our other models. :-)
It is standard in all of our truck campers being built currently. We are using the composite floor in conjunction with the enclosed underbelly for maximum insulation and durability.
Let me know if you have any more questions!
Christian
Appreciate the reply!!!!!
Plan to place an order for a new camper during 2016!
christianm
[quote timestamp="1447714503" source="/post/16653/thread" author="@exploringcarolina"]Appreciate the reply!!!!!
Plan to place an order for a new camper during 2016! [/quote]Whoo hoo!!!
