2015 16DBS winterizing "water heater bypass" location
Started by sheepcreek, September 18, 2016, 07:52:34 PM
sheepcreek
Hello all,
Getting ready to winterize for the first time and reading the manual, which states:  "bypass the water heater".
Does the 16DBS have a bypass for the water heater? I can't see one on the outside panel: there is just the anode and pressure relief valve.
Under the dinette seating is the water pump with three valves; one is 'closed' and two are in the 'open' position. Is that the bypass the manual
is referring to?
There is also a clear syphon hose that is attached to a white plastic tap which is 'closed'. I am assuming that is to be used to 'suck up' the RV antifreeze?
Sorry if this is a very dumb question, I did attempt to find the answer through the 'search' function first. I have attached a few
images for clarification
Karen
[img style="clear syphon hose" style="max-width:100%;" src="http://i113.photobucket.com/albums/n210/kabouterhouse/2015%2016DBS%20water%20pump%2013_zpsjyxj2z4u.jpg"]
[font size="3"]Karen,
The answers to your questions are Correct and Correct, in that order  :) . To bypass the WH and winterize you must drain the WH and reverse the three valves shown; one open and two closed. Then switch the small white valve and use the clear tubing to suck in antifreeze.
hogtyd
Edit: Charliem beat me to it, so what he says above! ^^^
Yes, the bypass is created by turning both the hot (red) and cold (blue) valves to the closed position so that the valve handles are no longer parallel to the hoses. Then turn the one middle valve handle that connects the blue and red hose sections so that it is open (handle parallel to the hose).
Graham
sheepcreek
Thank you Charlie and Graham, you guys are awesome!!!
