battery . . . Battery . . . BATTERYYYYYY
Started by drake, July 14, 2016, 04:42:16 PM
drake
So yeah, our 21BHS came with a garbage battery from the dealer and I'm looking at what to replace it with.
I know a couple golfers are the right way to go, but I'm starting to get a little thrifty after the trailer, a truck, a bunch of gear, etc...  We do have a Renogy 100W set of panels and controller, so I'm thinking we can dry dock for several days with no issue.
I think I've decided on this one:
https://www.batteriesplus.com/battery/rv/deep-cycle/12/sli31dtmagmdc
I'd like to take some weight off the tongue and am thinking about moving the battery to either under the bunk or on the rear bumper.  Anyone else done this?
Same question with spare tire, I can't believe they put it in front of the axle when tongue weight is already a bit of an issue on the 17's.
That battery should do fine. All AGMs work fine as deep cycle house batteries.
I wouldn't put it on the bumper without doing something like fasteddie did. Under the bunk will be fine.
A 105 AH battery should cover you for 3-4 days if you don't use the furnace or run fans 24/7.
drake
Thanks David. Your posts on the topic have been super helpful in my selection.
We're off for a couple weeks in the Bighorns soon, or I'd probably put the time into golf cart batteries.
Being able to check something off my list with minimal effort is too appealing right now!
