Camplite => Camplite Travel Trailers => Topic started by: jtelles3993 on March 19, 2015, 12:44:14 PM
Title: Interesting discovery...
Post by: jtelles3993 on March 19, 2015, 12:44:14 PM
I have 3500# axles, my tires are rated at 1760# each (7040# total), my Livinlite factory data plate says my trailer GVWR is 7000#.
Even though I'm still well under 5000# as currently loaded, I have plenty of TV for more if the trailer data is correct?
I sent Don an email with photo of my data plate and tire info to find out if I am reading all of this correctly, I'll report back.
Post by: jtelles3993 on March 19, 2015, 01:16:24 PM
Wow, I got a very quick response.
My CL is rated at 7000# GVWR and the data plate is correct. My 2015 unit was built Oct 2014 with the 3500# axles and the tires were matched accordingly. Don said they'll get the "web guy" to update the LL website asap.
Post by: spot1 on March 19, 2015, 02:45:57 PM
Took these photos of a 2015 21BHS @ D&H RV last year. The CampLite hitch is limited to 5,000lbs. The GVWR with both 3500lb axles is 7,000lbs.
What is your hitch capacity? The hitch capacity probably determines the maximum advertised weight.
Currently on the LL website for the 2015 21BHS:
"Box Length 21'-0"     Dry Weight *3,499 lbs.
Overall Length: 24'-0"     Load Capacity: *1,501 lbs.
Overall Width: 7'-0"     Hitch Weight: **440 lbs.
Height w/AC: 9'-8"     Grey Water: 32 gal.
Tire Size: 14"     Black Water: 28 gal.
GVWR: 5,000 lbs.     Fresh Water: 30 gal. "
[a href="http://s657.photobucket.com/user/vstromklr/media/2013/2014/IMG_5163_zpsfd2d37cb.jpg.html"]
[img style="max-width:100%;" src="http://i657.photobucket.com/albums/uu299/vstromklr/2013/2014/IMG_5163_zpsfd2d37cb.jpg"][/a]
[a href="http://s657.photobucket.com/user/vstromklr/media/2013/2014/IMG_5161_zpsbfc7d99c.jpg.html"]
(http://i657.photobucket.com/albums/uu299/vstromklr/2013/2014/IMG_5161_zpsbfc7d99c.jpg)
Post by: shovelhead on March 19, 2015, 03:03:41 PM
Exploring
Where is the Manufactured By plated located?
Post by: spot1 on March 19, 2015, 03:05:09 PM
[quote source="/post/8139/thread" timestamp="1426788221" author="@shovelhead"]Exploring
Where is the Manufactured By plated located?[/quote]It's close to the hitch on my camper & 21BHS I took photos of.
Post by: jtelles3993 on March 19, 2015, 03:41:20 PM
Yep, same here. So replacing the coupler is the trick to bump up GVWR if ever needed? The folks at LL/CL seem to have a disconnect between design and the finished product?
Post by: jtelles3993 on March 19, 2015, 03:41:50 PM
My plate is in the same location..
Post by: jtelles3993 on March 19, 2015, 04:10:51 PM
So I go back and tell Don about the weak link and asked LL to send me the right coupler. He responded that that's the only coupler they use. So I respond, then don't update your website (tongue in cheek).
They should be paying us.
Post by: charliem on March 19, 2015, 04:53:21 PM
[font size="3"]Another point for my argument that the coupler is mis-applied. The 5000# rating would only be valid when attached per the coupler manufacturer's design, that is, welded. LL drills the four bolt holes in their factory.
LL has been using the 3500# axles for some time. I noticed when shopping for my 21RBS in Oct 2013 that the GVWR was 7000#. When I took delivery of my "2014" 21RBS in Dec 2013 it had the 3500# axles and carried the 7000# GWVR on the sticker. The build date was 10/2013.
I replaced the original coupler with a heavier 2-5/16" coupler used on LL's toy haulers. Four additional info read my "Bent Coupler" thread.
[attachment id="954" thumbnail="1"]
[font size="3"]Although it doesn't show well in the picture the coupler is rated at 14000# with a tongue weight of 2100#. The "1" in the 14,000 is obscured by a scratch. Again, these ratings are valid only if welded as designed, but it's a lot stronger than the OEM coupler as installed by LL.
The GVWR on the trailer label is only valid for the ST tires shown. I ordered the off road package which came with LT195/75R14 BF Goodrich tires. Each tire is rated at 1710# so my GVWR is limited to 6840#.
BTW, surfsup, just because your GVWR is 7000# doesn't mean you have to carry everything you own :P. Leave something to come home to  :D.
Post by: jtelles3993 on March 19, 2015, 06:54:06 PM
Hahaha, no problem Charlie. Until I replace the coupler it'll stay under 5k# - which is a gracious plenty right now for the two of us.
Seems like most of you guys were already aware of this info, but I was surprised when I found out about it. I did find a few nice 7000#  2" ball couplers online for when I'm ready to upgrade.
Post by: spot1 on March 19, 2015, 07:15:24 PM
Found many weld on a-frame couplers on line and here's some bolt on a-frame couplers at E-Trailer:
http://etrailer.com/dept-pg-Trailer_Coupler-sf-A~Frame_Coupler-pt-Bolt~On.aspx
Our CampLite 11 has a bolt-on straight coupler.
Post by: charliem on March 19, 2015, 07:32:10 PM
[font size="3"]Yes, Bill, there are plenty of weld on and bolt on couplers available. They are all made of steel, which cannot be welded to aluminum. Welding relies upon both surfaces becoming molten and flowing together. Steel melts at a much higher temperature than aluminum.
The bolt on couplers would work fine if properly installed. Note that the bolt on couplers have holes along the sides, requiring bolts going into the trailer frame. LL tried to use a weld on coupler in a bolt on configuration, but didn't include the side bolts. That's all that's missing. BTW, LL does use the side bolts on the toy haulers, as you conveniently pointed out to me  ;).
Post by: charliem on March 19, 2015, 07:48:44 PM
[quote source="/post/8158/thread" timestamp="1426802046" author="@surfsup"] I did find a few nice 7000#  2" ball couplers online for when I'm ready to upgrade.[/quote][font size="3"]Yes, there are 2" couplers capable of up to 10000#. Just be aware that the hole for the tongue jack is fixed in position by the lower plate. This will affect how the new coupler fits on the A-frame and how you can bolt it on. [/font]
Post by: spot1 on March 20, 2015, 05:10:42 AM
[quote source="/post/8161/thread" timestamp="1426804330" author="@charliem"][font size="3"]Yes, Bill, there are plenty of weld on and bolt on couplers available. They are all made of steel, which cannot be welded to aluminum. Welding relies upon both surfaces becoming molten and flowing together. Steel melts at a much higher temperature than aluminum.
[/font][/quote]Charlie, I would not consider welding carbon steel to aluminum.
Post by: charliem on March 20, 2015, 09:43:09 AM
[quote timestamp="1426839042" author="@exploringcarolina" source="/post/8190/thread"]Charlie, I would not consider welding carbon steel to aluminum.
[/quote]Bill,
I was sure you knew that, but I wanted to answer the inevitable question from others: "why not weld it?" More of a general general education thing.
Post by: spot1 on March 20, 2015, 11:18:53 AM
[quote source="/post/8193/thread" timestamp="1426855389" author="@charliem"][quote source="/post/8190/thread" timestamp="1426839042" author="@exploringcarolina"]Charlie, I would not consider welding carbon steel to aluminum.
[/quote]Bill,
[/quote]Charlie, Always wondered about your avatar. Love flying airplanes & things made out of aluminum, but railroading was my real job.
Post by: pinstriper on March 20, 2015, 11:23:35 AM
I think there's a [a href="https://www.youtube.com/watch?v=ExSlyoVTX3I"]simple explanation[/a].
Post by: charliem on March 20, 2015, 06:34:10 PM
[quote timestamp="1426861133" source="/post/8199/thread" author="@exploringcarolina"]Charlie, Always wondered about your avatar. Love flying airplanes & things made out of aluminum, but railroading was my real job.
[/quote][font size="3"]Bill, not to drag this thread too far off course but one of my hobbies is railroading and model railroads. Although I'm stuck in Florida I call Colorado home so I model the D&RGW in HO. My avatar is Cumbres & Toltec Scenic RR #489, a 2-8-2 K36 steamer originally from D&RGW. So when the weight distribution pro/con discussions get hot and heavy I just point to #489 and say "Friends, that's my TV and I don't need no stinkin' WDH"  :P[/font]
Post by: spot1 on March 20, 2015, 06:57:54 PM
Charlie,
Once upon a time a historical society wanted to bring their steam engine across the turntable and park the steam engine in our roundhouse. Problem was the Steam Engine weighed 995,000 lbs. I told them if they could find someone on the Railroad to approve that steam engine crossing the turntable, they could bring it in the shop. No one approved it. We would bring the 611 J class in the shop on a regular basis. The 611 only weighed in at 500,000lbs.
Surfsup, Sorry about the thread derailment, let me re-rail  :):
The bolt on coupler capacity on my 2010 CampLite 11 is 5,000lbs, but the axle GVWR is 2200lbs. The advertised GVW for my TT is 2200lbs. Looks like LL uses the lowest weight capacity of the coupler or axle/axles capacity.
Post by: charliem on March 20, 2015, 07:17:33 PM
[font size="3"]I visited the VA Museum of Transportation last year hoping to see 611, but alas, she was off to another shop for some final work. So I bought a video. By now she should be close to steaming up.
On the CL11 GVWR, it just means LL has standardized on the 5000# coupler for all their small trailers, up through the 21s. Good from a manufacturing and inventory standpoint. No problem there. The limit on your GVWR is the axle and tires. You won't have the bent coupler problem on such a light rig.
Send me a PM and tell me what you did for the RRs. Which shop?
