Camplite => Camplite General Q & A => Topic started by: kycamper on March 15, 2015, 12:23:19 AM
Title: Backup Camera Installation
Post by: kycamper on March 15, 2015, 12:23:19 AM
I have decided to treat myself to a Rear View Safety two camera system RVS 770614. Has anyone installed one of these? I am curious how I will route the wire from the camera at the rear of the trailer to my TV. No clue. I asked the company if I can preview installation instructions, but the buzz on the web is that the instructions are weak, at best. What do you recommend I do? Once again, thanks.
Post by: leslie on March 15, 2015, 01:27:45 AM
Quote from: @gleamb" source="/post/7806/thread" timestamp="1426389799I have decided to treat myself to a Rear View Safety two camera system RVS 770614. Has anyone installed one of these? I am curious how I will route the wire from the camera at the rear of the trailer to my TV. No clue. I asked the company if I can preview installation instructions, but the buzz on the web is that the instructions are weak, at best. What do you recommend I do? Once again, thanks.
The instructions are VERY weak. I had my dealer install the rear view camera onto the back bumper of my Camplite. Then the wire went under my trailer, fastened by metal clamps along the way. The technician fed the wire to the tongue, and there is another connection there. It connects to another wire that was placed just under the bumper of my tow vehicle, on the opposite side of the hitch from my 7-pin connector. It is very easy to detach when unhitching, which I like.
The other camera was fastened to the midpoint of the bumper of my tow vehicle, a Jeep Grand Cherokee. The wires go under my Jeep and come up through the engine to connect to the monitor that I wanted on my dash.
I am not at all mechanically inclined, and my husband has a back problem causing him great difficulty in getting down on the ground and back again, so we were happy to have technicians handle this. They told me it was very simple to install up to this point.
The only problem they ran into was when it came time to get power to the monitor, and where to run the wire to get power.  They explained the situation to my husband and me, and we came up with the solution about where to run that wire.
If all else fails, I would recommend hiring a tech who knows what he is doing.
Post by: drdave on March 15, 2015, 09:37:13 AM
I've run 12V power to the rear bumper of my CL, and I'm also about to install a backup camera.    It's very easy to run cables underneath the trailer.   There are plenty of nooks and crannies to tuck cables in and out of the way.   A handful of zip ties and everything will stay in place.    As long as you don't mind crawling under your trailer it's quite easy.
Post by: kycamper on March 15, 2015, 09:49:39 AM
Thanks for the info. I envisioned having the trailer camera mounted up high near the running lights and wondered how to run the wire down to the trailer bottom. Where did you find the tech to install your setup? May I be so bold as to ask about how much it cost to install. My wife wants to know! Thanks y'all.
Post by: charliem on March 15, 2015, 11:38:18 AM
[font size="3"]gleamb,
The RVS system should work for you. I had an RVS  wireless system on my previous rig and it worked fairly well for a wireless system, but when I tried it on my new rig (CL 21 plus 2013 Tacoma) it bombed.  This was due to the analog wireless technology they used. [/font][font size="3"]The Bluetooth system in my whiz-bang new truck wiped it out. [/font][font size="3"]The 770614 is wired so it will work much better. Wired is always better than wireless for video quality. The installation manual can be found here: [a href="http://www.rearviewsafety.com/media/mconnect_uploadfiles/r/v/rvs-770614_lowres.pdf"]http://www.rearviewsafety.com/media/mconnect_uploadfiles/r/v/rvs-770614_lowres.pdf[/a]. I finally went with a Voyager wireless system which works very well, but is also very expensive. So if you've settled on a wired you're on the right track.
I assume you want one camera on the back of the trailer and one on the TV? RVS offers hardware and cables designed for TV/TT application, but there are other solutions. I mounted a camera on the roof just above the three clearance lights. You can route wires over the roof edge, into and through the center light fixture. This will get you inside the trailer inside the black cable molding at the ceiling of the bathroom. From there I would route the wire down to and through the floor to end up outside and under the trailer. Then run forward to the tongue and install the proper connectors between the TT and TV. Ditto for the wiring of the TV. I'm not sure how the 770614 handles DC power to the cameras, but you want the camera on the TT powered continuously while you're driving. Several ways to do this either from the TV when hooked up or from the TT through a switch.
Post by: pinstriper on March 15, 2015, 12:39:41 PM
Buy it at Camping World. Aren't they supposed to do installation for $35 for Good Sam members ?
Post by: leslie on March 15, 2015, 12:56:09 PM
Quote from: @gleamb" source="/post/7826/thread" timestamp="1426423779Thanks for the info. I envisioned having the trailer camera mounted up high near the running lights and wondered how to run the wire down to the trailer bottom. Where did you find the tech to install your setup? May I be so bold as to ask about how much it cost to install. My wife wants to know! Thanks y'all.
The techs at the dealer installed the system for me. I do not know how much the charge was, because they did it before I took delivery, and it was bundled into installation of several things I wanted installed prior to delivery. They told me what the total charge would be, and I accepted it. There was quite a bit of negotiation involved.
The techs went through the pros and cons of installing the camera high up on the trailer vs placing it on the bumper. We decided to go with the bumper.
Post by: nmken on March 15, 2015, 01:52:52 PM
I've got a wired camera that I installed on the bumper.  My TV is a 2004 4runner so also had to do all the wiring for it - definitely was a major job.  One simplification I decided on was to tap into the rear lights power line for the camera - so my lights need to be on for the camera to work - works fine for me.  I had tried a couple of the cheaper wireless cameras before putting in the wired cameras - they proved to be unreliable for me.  I emphasize though they were very cheap on amazon - the little wireless transmitter/receiver are apparently not designed to run for extended periods of time - they burned themselves up.
Post by: pinstriper on March 15, 2015, 02:00:05 PM
Quote from: @nmken" source="/post/7845/thread" timestamp="1426438372I've got a wired camera that I installed on the bumper.  My TV is a 2004 4runner so also had to do all the wiring for it - definitely was a major job.  One simplification I decided on was to tap into the rear lights power line for the camera - so my lights need to be on for the camera to work - works fine for me.  I had tried a couple of the cheaper wireless cameras before putting in the wired cameras - they proved to be unreliable for me.  I emphasize though they were very cheap on amazon - the little wireless transmitter/receiver are apparently not designed to run for extended periods of time - they burned themselves up.
Why didn't you come off the backup light power ?
Post by: charliem on March 15, 2015, 02:59:54 PM
[font size="3"]A few points on backup and rear view cameras:
[ol type="decimal"][li]A backup camera is generally used only while backing up or hitching up. As such it can be powered from the backup light line on the TV.
[/li][li]A rear view camera operates continuously and is used on the highway for lane changing and general situational awareness behind you. As such it needs a continuous source of power..
[/li][li]A rear view camera on the back of a trailer may be powered from the "parking" or running lights. This is sometimes convenient, but requires the running lights be on even in daylight.[/li][li]The trailer mounted rear view camera can be powered from either the trailer battery through a switch or from the TV electrical system with the proper wiring. The latter would be the preferred method, IMO.[/li][li]The trailer mounted rear view camera does not replace the spotter (wife) when maneuvering into a campsite. Don't leave home without them.[/li][li]nmken suggests some backup cameras cannot withstand continuous power. This may well be true. Before you buy, check with the manufacturer. Rear View Safety has some helpful people available by phone, but you have to speak Brooklyn.
[/li][/ol]
Post by: shovelhead on March 15, 2015, 04:51:28 PM
I went with wireless... Not too expense and so far no channel interference.
Post by: kycamper on March 15, 2015, 07:33:36 PM
Thanks, charliem. Once in the bathroom wall, is it hard to fish the wire to get it under the trailer? Is there insulation in the outside wall, or is it hollow??
Leslie....what were the pros and cons of a bumper vs. a roof mount? I have a new bike rack centered on my bumper, so I lean towards a high installation.
I am definitely going with the wired version. I will get the license mount for the hitch and mount the other camera on the trailer.
Post by: pinstriper on March 15, 2015, 08:36:24 PM
[quote source="/post/7850/thread" timestamp="1426442394" author="@charliem"][/quote]It has a whine/complain mode ?
Post by: charliem on March 15, 2015, 09:00:35 PM
[quote source="/post/7868/thread" timestamp="1426462584" author="@pinstriper"][quote source="/post/7850/thread" timestamp="1426442394" author="@charliem"][/quote]It has a whine/complain mode ?
[/quote][font size="3"]Yes it does, as an option. And they even give you a discount if you order it  :D
Post by: charliem on March 15, 2015, 09:23:18 PM
[quote source="/post/7861/thread" timestamp="1426458816" author="@gleamb"]Thanks, charliem. Once in the bathroom wall, is it hard to fish the wire to get it under the trailer? Is there insulation in the outside wall, or is it hollow??
I am definitely going with the wired version. I will get the license mount for the hitch and mount the other camera on the trailer.[/quote][font size="3"]It's easy. The black wire mold conceals the wires to the rear marker lights as well as other circuits crossing the trailer at that point. If you remove the molding, held on by about 4 screws, you will see the holes behind each of the 3 marker lights where their wires pass through the foam wall insulation and wall board. On the outside you remove the amber lens and file a small notch on the bottom of the lens. Run the wires from  the camera through the hole in the fixture into the camper and replace the lens with the notch on the bottom. Seal with goo. Once inside it's easy to snake the wire to the left and into the cabinetry above the sink.  Once inside the cabinet it should be easy to find a path to the floor somewhere near the WH. Drill a hole and you're under the trailer. Seal with goo. I stopped inside the cabinet because I only needed DC power and I had LL run 12V to the cabinet. I mounted a toggle switch in the cabinet front surface and use it to turn the camera on/off. Therefore I didn't go all the way to the floor, but it shouldn't be too hard. You will also be running a video cable so plan for it. You may have to drill bigger holes to accommodate connectors or take the connectors off first. Don't worry about coiling up some excess video cable somewhere if it makes installation easier.
I mounted my camera on the roof, centered left/right, and as close to the roof edge as I could. The high position has several advantages. I'd be interested in hearing Leslie's reason for bumper mounting.
Post by: leslie on March 16, 2015, 10:49:15 AM
Well, this is how the discussion went:
Mounting the camera high up on the trailer was going to cost a lot more money, because it was going to be a lot more work for them to run the wiring inside the camper. Also for me to consider was that the camera attached with 4 screws, which meant 4 insertions in the exterior shell, presenting 4 additional areas for leaks to develop and more work for me in the future to keep those screws caulked. An advantage to placing the camera higher would be a more panoramic view of traffic behind me as I go down the road.
Mounting the camera on the bumper was a much simpler process for the techs, so there would be a smaller charge for the work. As far as maintenance, all I have to do is occasionally check to make sure the camera was tight. The camera has markings to show me how far away the back of the trailer is from objects, which is more helpful with the view from the bumper than with a higher camera placement.
I can see vehicles in back of me just fine, as well as when they are passing. Once installed, it is possible to adjust the angle of the camera up and down, in order to change your view higher or lower. There is no adjustment possible for side to side adjustment.
I am really happy with this system. I like the microphone with the camera. The cameras are very secure on the bumpers. I still have the systems display on the Jeep's monitor and a separate monitor for the rear traffic view while in motion.
I hope you find this info helpful.
Post by: charliem on March 16, 2015, 11:36:12 AM
[font size="3"]Leslie et al,
Me thinks you found a lazy tech. As I outlined, installing on the roof is only marginally more difficult if you know what you're doing. In defense of your tech, he may not have been familiar with Camplites. One of the beauties of the CLs is everything is accessible. The camera is much safer on the roof away from physical damage and unauthorized "borrowing" in a parking lot. [/font][font size="3"]There is no maintenance required except maybe an annual lens cleaning. [/font][font size="3"]I think the view from the top makes it easier to judge distances and see over close in objects like cars stopped directly behind you. It also seems the camera could be blocked if you carry anything else on the bumper. Most RVs you see with cameras have them up top.
Post by: kycamper on March 17, 2015, 12:14:42 AM
charliem....are there two wires coming from the camera on the back of the trailer....one for power and another for video??
Any chance of a picture of your " notch" in the amber lens, shown the routing of the wire(s)??
I know that would be a tough photo to take. Thanks again. You are always helpful.
Post by: leslie on March 17, 2015, 01:50:52 AM
Gleamb, if you are going with the Rearview Safety cameras, the "instructions" that came with mine consisted of a picture showing the wiring, and that was all. I think the diagram would help you answer that question.
My trailer and the paperwork for the cameras are in Florida waiting for me to pick them up and move north. You will probably have yours installed before I am back with the trailer!
Post by: kycamper on March 17, 2015, 01:22:30 PM
I'm in no hurry. Thanks. I think Rearview is sending me a copy.
Post by: charliem on March 17, 2015, 01:40:53 PM
[font size="3"]Gleamb,
I got kinda wordy with my reply so check your PM.
Post by: kycamper on March 17, 2015, 07:13:35 PM
hope you heal quickly, charliem. I know lots of folks going through this type of procedure. The rehab takes time. Be well.
Post by: nmken on March 19, 2015, 05:03:03 PM
We are heading out soon for our first real trip since we picked our 2015 up last October - heading south!  You can see the camera on the top of our License Plate.  I'm really happy with this extended rear bumper - it will be sad to see Camplite stop offerring it as an option.
Post by: charliem on March 19, 2015, 05:13:06 PM
[quote source="/post/8152/thread" timestamp="1426795383" author="@nmken"]  I'm really happy with this extended rear bumper - it will be sad to see Camplite stop offerring it as an option.[/quote][font size="3"]Is there some indication LL is discontinuing this option?[/font]
Post by: nmken on March 19, 2015, 05:50:56 PM
When we were picking up our CL, another couple was touring the manufacturing floor and had mentioned wanting to permanently mount a 4kw generator - wanted to know if the rear deck could hold the weight.  The floor supervisor went into a bit of a tirade on how bad an idea that was and that they were most likely going to stop offering the deck because of liability issues - not sure if they have or haven't but they are at least contemplating.
Post by: shovelhead on March 19, 2015, 06:42:30 PM
I have a friend that works welding aluminum all day. Thinking about how he can beef up my bumper to add storage box. I'd like to know what LL perceives as a liability with this option.
Post by: nmken on March 19, 2015, 08:19:34 PM
their concern is how we can overload the rear bumper with weight that takes weight off the tongue, resulting in a badly balanced load. The 4k generator the guy asked about weighed over 150 lbs which would all come off the tongue weight
Post by: lanell on March 19, 2015, 09:07:37 PM
We pick up our DB16  in the morning , LL built it to order, we had a rear deck installed. So for now there still making them.
Post by: whoofit on March 19, 2015, 09:28:12 PM
We are eventually doing a 2 position mountain bike rack in the rear. I want more of a combination backup/security camera back there. Have experience with the security cameras and will go with a wide angle megapixel wireless IP type in a dome high and centered.
Snatch and grabs happen while parked. Even in traffic in some areas. I'd like a dual purpose solution. The current TV has a nice monitor built-in to the dash already with A/V inputs. Only problem is it does not allow A/V inputs to be active while moving or in gear. Need to figure this one out. I'm sure there is a way.
Post by: kycamper on March 20, 2015, 06:20:35 PM
Snatch and grabs???? That's why they invented locks. For honest people!! Happy Trails.....
Post by: whoofit on March 21, 2015, 02:21:00 PM
[p]Yes! Locks keep honest people honest. It's the other ones I'm most concerned with.
Just my AM bike alone costs ...err...umm... Now that I think about it the real thieves were in the bike shop to begin with! It is made from carbon fiber including the rims. Just prying on it renders it useless and maybe even damaged beyond repair. Everything is quick disconnect too. Suppose I could disassemble it before placing it on the rack but then I wouldn't need a rack. I'd need a bucket for inside the trailer.
I belong to some forums and have heard time and time again about thieves coming along at stop lights and swiping the seats, bars, wheels...even the ding dong bells and streamers!!! Those streamers cost a fortune!....ha. Seriously though, the saddles alone with dropper posts are four hundred to replace and those are a 5 second item at best.
It would be good to know what's going on back there at all those highway rest stops and Walmarts I've been dreaming about and it would be awesome to have  a video record of the event.[/p][p]
[/p][p]I also promise to never record the neighbors in the next site behind us. That can be illegal especially with the audio portion enabled.
Happy Trails to you as well!
Post by: charliem on March 21, 2015, 02:33:52 PM
[font size="3"]FWIW, I have the Voyager camera mounted on the roof, as close to the rear edge as possible, where it's out the reach of passersby. The camera FOV is spec'd at 93 degrees horizontal, 66 degrees vertical, 117 degrees diagonal.  With the camera positioned to give a good view to the rear I can see the handlebars of both bikes on their carrier. Very comforting while rolling down the highway.
Post by: kycamper on March 21, 2015, 09:21:27 PM
Actually, I just received a two camera setup made by E Sky and purchased on Ebay for about half the price of the one from Rear View Systems. Everything looks good. I will tackle the installation sometime next week. Hardest part will be routing the wiring through my Suburban and mounting the monitor. I will do a product review once it's installed.
Post by: shonsu on March 31, 2015, 09:25:02 PM
I just got these in today:
http://www.amazon.com/gp/product/B00TCJKYDI/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
http://www.amazon.com/gp/product/B00T2GX37A/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I ran a quick test and since it is wifi the distance is great.  I was able to pick it up all the way from one side of the house to the other (through walls and all).
I didn't want to drill holes or anything which is why I went with the license plate one.  They were cheap enough that if they don't last it won't break the bank to replace them.  We'll see how it goes.
