Quicksilver => QuickSilver Toy Haulers => Topic started by: katienoellewis on March 25, 2014, 07:14:32 PM
Title: Concern about placement of waste pipe....
Post by: katienoellewis on March 25, 2014, 07:14:32 PM
We have a new Axxess Toyhauler Polaris edition that we are getting ready to take out for the first time this weekend. Upon looking over everything, we're a little concerned about the placement of the waste pipe..... It is really low to the ground. It seems like it would be hit by any bump/rock we may encounter.  Is this the way it looks on all Livin' Lite products? Is this normal for a toyhauler?
[attachment id="38" thumbnail="1"]
Post by: tommyc on March 25, 2014, 10:06:43 PM
They do sit pretty low. Considered having the offroad package installed on our trailer to gain a couple more inches but in the end decided that just being aware that it is that low and planning accordingly was a better option for us.
Post by: davidb on July 16, 2014, 06:42:07 AM
                                                         [attachment id="243" thumbnail="1"]
I was also disappointed with how low my drain fittings were, I loosened all the clamps thinking I could move the pipes up an inch or two, but they wouldn't budge.
I installed some lift kits from Perfect Casita that raised the body an additional 3 inches on my 6x15 vrv toyhauler.
Post by: baldboy on August 12, 2014, 09:33:01 PM
This lift is one of the next things I am going to install!  Thank you for sharing!
Post by: baldboy on November 01, 2014, 07:26:12 PM
[p]I just ordered a set, well, two sets...
How was the install? [/p][p]
[/p][p]They are on sale for $79.95 right now if anyone is interested.[/p]
Post by: davidb on November 01, 2014, 09:49:36 PM
The install is pretty basic.Support trailer by frame,remove wheels,unbolt axle one at a time, bolt blocks in then bolt axle to blocks.
I extended the brake wires with solder and heat shrink, that was a good time to get rid of the original quickee wire splicers.
Post by: thudd3r on April 05, 2015, 10:19:43 PM
[quote timestamp="1414889376" author="@davidb" source="/post/4719/thread"]The install is pretty basic.Support trailer by frame,remove wheels,unbolt axle one at a time, bolt blocks in then bolt axle to blocks.
I extended the brake wires with solder and heat shrink, that was a good time to get rid of the original quickee wire splicers.[/quote]is this the item?
Casita (Dexter Torflex #10) Axle Lift Kit
Item#: 610079216846
thanks
kev
Post by: oprlrt on June 18, 2015, 06:19:33 PM
You will need the serial number off of axle when you call Casita to tell which kit you need. On my axxess 8.5x22 it was the 11, it may be listed some where in the paper work to.
Pest
Post by: ducatirdr on June 24, 2015, 09:54:41 AM
Of course this changes the lift height of your hitch ball to 3" higher...
