OK, my Camplite is out of storage and I am working my way south. I have only been in the camper during daylight, so I haven't turned on an interior light for several weeks. Tonight, radio works, exterior light turns on, but no interior lights will turn on. Will I have to take each interior light apart to look for a problem?
Out 14DBS has a master light switch near the door that must be ON before the ceiling fixtures will go on. They each have a switch on the fixture for off/1 light/2 bulbs. Your 21BFG may be different.
The light over the sink, and the bathroom, or crapper if you will, is independent.
After that, I guess you are checking fuses.
Master light switch? Oh, the things nobody told me... or maybe I don't have one? I will check.
My 13QBB also have a master light switch
[quote source="/post/5878/thread" timestamp="1420601539" author="@leslie"]Master light switch? Oh, the things nobody told me... or maybe I don't have one? I will check.[/quote]On our's it's on the side of the kitchen cabinet to the left when you walk in the door. I would expect yours to be in the same spot.
[quote source="/post/5881/thread" timestamp="1420638476" author="@tinkeringtechie"][quote source="/post/5878/thread" timestamp="1420601539" author="@leslie"]Master light switch? Oh, the things nobody told me... or maybe I don't have one? I will check.[/quote]On our's it's on the side of the kitchen cabinet to the left when you walk in the door. I would expect yours to be in the same spot.[/quote]
Same spot for me next to the water heater switch in my case
I will look as soon as it stops snowing.
Snow...looks like you aren't far enough south yet :)
[quote timestamp="1420639540" source="/post/5882/thread" author="@paul"][quote source="/post/5881/thread" timestamp="1420638476" author="@tinkeringtechie"]On our's it's on the side of the kitchen cabinet to the left when you walk in the door. I would expect yours to be in the same spot.[/quote]Same spot for me next to the water heater switch in my case[/quote][p]Guys, remember ! This was a custom build. Who knows if she even got the switch, or where they mounted it ? Might be inside one of the cabinets, or in the passthru storage, or under the mattress or something. All bets are off when you go CUSTOM.[/p][p]
jk, it's gonna be right near the door or where the water heater switch and other switches are.
Quote from: @pinstriper" timestamp="1420647573" source="/post/5887/threadQuote from: @paul" timestamp="1420639540" source="/post/5882/threadSame spot for me next to the water heater switch in my case
I thought the same thing. I was going to respond to her with "It's right next to your slideout switch..." and then I thought *wait... she doesn't even have a slideout... nevermind*
Thanks so much for the help. The switch is next to the 120 volt outlet on the left as I come into the trailer. All the lights are working.
