Ask the Factory => Ask the factory => Topic started by: nmken on October 28, 2014, 02:02:44 PM
Title: Thanks to Don and Mike at Livinlite
Post by: nmken on October 28, 2014, 02:02:44 PM
I wanted to shout out to Don and Mike for getting my trailer to me at the factory.  We had some logistics problems with paperwork that delayed the pickup a day but in retrospect a small annoyance.  They did everything they could to make us feel welcome at the factory and I really enjoyed the tour of the factory to see firsthand the workmanship that goes into all of our trailers - first rate!
I've gotten the trailer back and had my first camping weekend - everything is working great - nothing to complain about at all - I was fortunate enough to get a perfect trailer, pulls fine with my v6 4Runner.
I should mention that it was perfect when it left the lot, but unfortunately we had a collision with a semitruck on the way home, trailer swayed into the side of a semi.  It is a testament to the construction that the semi looked worse than my camplite that got off with a 1" 'ding'.  In retrospect I think the pickup at the factory resulted in it being too lightly loaded that contributed to the sway - for folks doing this in the future, remember to make sure you have good weight distribution when you pick it up, even if it means you need to load it up some (water, gear, etc).
Post by: david on October 28, 2014, 03:23:56 PM
The 16TBS does have a light tongue weight as delivered- about 240 lbs for mine. That can definitely contribute to sway. Put some stuff in the forward pass through compartment to help and maybe add a second battery to get it up well above 300 lbs.
Post by: nmken on November 27, 2014, 12:48:49 PM
[p]Not quite perfect...  I discovered that the plastic low point drain valves were both leaking.  The leak appears to have been getting steadily worse.  So I had to invest in the Pex cramp tool to replace these.  No big deal except the factory didn't leave me ANY excess pex on these lines to work with.  Note to factory, please make these drain lines half an inch longer, just in case![/p]
