Camplite => Camplite Mods / Upgrades => Topic started by: pinstriper on March 18, 2014, 10:59:04 AM
Title: Flat Tire Solutions
Post by: pinstriper on March 18, 2014, 10:59:04 AM
[p]What's the preferred solution people use ?[/p][p]
[/p][p]1) Replace the tires with run-flats ?[/p][p]
[/p][p]2) Mount a spare tire carrier and buy a spare.[/p][p]
[/p][p]3) Carry a can of compressed goo.[/p][p]
Post by: tinkeringtechie on March 18, 2014, 05:28:39 PM
 You forgot option 4: Get a AAA membership  :)
Post by: admin on March 19, 2014, 09:18:30 PM
I keep a spare tire maintained and usually also care a plug kit with a compressor. The "compressed goo" works but last time I used it on my car tire I was charged a ridiculous amount to have it repaired b/c the shop claimed it took a lot of extra work to wash out the tire. Although with the spare and plug kit I dont think I have to worry  to much about being without a usable tire.
Post by: pinstriper on March 19, 2014, 10:21:46 PM
I stopped off at the regional chain this afternoon and put the question to them. With a clamp on mount, a rim, and the tire itself, looking in the neighborhood of $150 to carry a spare. And adds about 50# right near the tongue, plus I gotta carry some sort of trailer jack.
I posed the question of how effective, and how heinous they view the canned goo. He shrugged his shoulders and said "fact of life for us - a lot of new cars come with no spare, just the can of goo and an inflator". His best recommendation was to get some sort of roadside assistance, and carry a can of goo. Not a great solution, but the best compromise for the risk, and to avoid the extra weight.
Post by: vmcmn on March 20, 2014, 01:21:17 PM
Just make sure that if you use the canned goo that you let the people that are replacing or fixing the tire know that it had been used. The stuff can be highly explosive and flammable (they don't post the warning on the can for nothing) I saw a tire that came into the shop I worked at go BOOM,thank god the mechanic wasn't hurt just stunned. Plus its a real pain to clean out of a tire,that's why they charged you so much Sean.
Post by: pinstriper on March 23, 2014, 09:23:09 PM
Whelp, I got under the trailer to drain the fresh water tank (dealer very helpfully topped it off so I could pull a couple hundred extra pounds around) and I discovered by 14DBS actually does have a spare ! So now all I gotta do is figure out how to jack it up in the event of a flat.
Post by: admin on March 23, 2014, 10:54:38 PM
Dont you have a jack in the tow vehicle?
[Sent from my phone]
Post by: pinstriper on March 23, 2014, 10:59:24 PM
Yes, the bottle jack that came with her. But I wonder if I ought to consider something trailer-specific.
Post by: tinkeringtechie on March 24, 2014, 10:47:05 AM
On a dual axle trailer I would use blocks or a ramp to raise the good tire and the bad one will follow. Here's an example of what I mean: http://youtu.be/-jE_x_TjlOI
Much faster than a jack and usually you have some blocks or ramps with you already.
Post by: djsamuel on March 24, 2014, 01:29:03 PM
Do you use this? I was thinking of getting this for my 21BHS , but was wondering if, due to the independent axles, if the one wheel would actually make it off the ground.
Post by: tinkeringtechie on March 24, 2014, 01:48:28 PM
I have the Anderson "camper levelers", which are a slightly shorter version of this that can fit between the wheels. I plan to use them instead of leveling blocks, but I will also test with just one to see if it could be used for tire changing. I'm picking up my 21BHS this weekend, so I'll report back next week. My thought on the independent axles is that it would actually help. Most of the old school leaf spring double axles have a linkage between the two that allows one to go up while the other goes down (creating even more travel). So compared to that design, I would expect the independent axles to have less travel and therefore work better with this approach. If the rapid jack isn't tall enough, you could get the "trailer aid", which has 5.5" of lift (but is bulkier):
[a href="http://www.amazon.com/Trailer-Aid-Plus-Tandem-Changing/dp/B001V8UKBY/"]http://www.amazon.com/Trailer-Aid-Plus-Tandem-Changing/dp/B001V8UKBY/[/a]
Post by: djsamuel on March 24, 2014, 04:34:03 PM
[quote source="/post/283/thread" timestamp="1395679708" author="@tinkeringtechie"]I have the Anderson "camper levelers", which are a slightly shorter version of this that can fit between the wheels. I plan to use them instead of leveling blocks, but I will also test with just one to see if it could be used for tire changing. I'm picking up my 21BHS this weekend, so I'll report back next week. My thought on the independent axles is that it would actually help. Most of the old school leaf spring double axles have a linkage between the two that allows one to go up while the other goes down (creating even more travel). So compared to that design, I would expect the independent axles to have less travel and therefore work better with this approach. If the rapid jack isn't tall enough, you could get the "trailer aid", which has 5.5" of lift (but is bulkier):
[a href="http://www.amazon.com/Trailer-Aid-Plus-Tandem-Changing/dp/B001V8UKBY/"]http://www.amazon.com/Trailer-Aid-Plus-Tandem-Changing/dp/B001V8UKBY/[/a][/quote]Thanks for the info.  Enjoy your 21BHS!
Post by: tinkeringtechie on April 28, 2014, 05:46:30 PM
I finally got a chance to try the Andersen camper levelers and unfortunately they didn't even fit between the tires >:(... For tire changing that wouldn't be a problem since you only need to raise one wheel, but I need to use both at the same time for leveling. After a bit of research it looks like you can actually trim the front edge to make it fit. I haven't had a chance to trim it yet, but I'll post back once I do.
Post by: tinkeringtechie on June 09, 2014, 01:58:25 AM
I finally got a chance to try the camper levelers this weekend. They worked very well. I had to trim off about an inch to get them to fit, but it didn't seem to affect the functionality:
[attachment id="163" thumbnail="1"]
I had a perfectly leveled and chocked camper in a couple seconds and I also tested that they would work for changing a tire. I would highly recommend them.
Post by: djsamuel on June 09, 2014, 06:58:47 AM
Thanks for the update!
Post by: fasteddieb on September 20, 2014, 06:25:41 PM
I got my Anderson Levelers a few days ago.
Definitely needed to be trimmed, and the instructions say up to 4", which I did, at an angle using a Sawzall:
(https://farm6.staticflickr.com/5577/15301061932_42a6e3f6b9.jpg)
Still a fairly tight fit on my 21BHS - took some wiggling to get it in place on my gravel pad:
(https://farm6.staticflickr.com/5579/15278389356_a1c3b091e3.jpg)
Wonder if I should trim the other one for a more symmetrical lift?
Post by: tinkeringtechie on September 20, 2014, 10:15:43 PM
[quote source="/post/3687/thread" timestamp="1411248341" author="@fasteddieb"]I got my Anderson Levelers a few days ago.
[img src="https://farm6.staticflickr.com/5577/15301061932_42a6e3f6b9.jpg"]
[img src="https://farm6.staticflickr.com/5579/15278389356_a1c3b091e3.jpg"]
Wonder if I should trim the other one for a more symmetrical lift?[/quote]I trimmed both so I could set them at the same point easily. It actually looks like from your picture that your wheels are closer. When I trimmed mine I didn't have to remove any of the circular cavities and it still fit... Maybe the off-road package has a wider gap?
Post by: fasteddieb on September 21, 2014, 09:41:38 PM
Got 'er done!*
[a href="http://youtu.be/AG7-aM3DfPQ"]http://youtu.be/AG7-aM3DfPQ[/a]
Post by: jeffrey on November 05, 2014, 06:00:26 PM
[quote source="/post/1405/thread" timestamp="1402289905" author="@tinkeringtechie"]I finally got a chance to try the camper levelers this weekend. They worked very well. I had to trim off about an inch to get them to fit, but it didn't seem to affect the functionality:
I had a perfectly leveled and chocked camper in a couple seconds and I also tested that they would work for changing a tire. I would highly recommend them.[/quote]Before my trip back to NM I tried two 2x8's stacked and that amazingly was enough to lift a tire off the ground. Much much simpler than using a jack!  Camper levelers are on my wishlist though.
Post by: runningwriter on November 21, 2014, 10:18:28 AM
I travel with a full size spare. Our tow vehicle jack works on the camper but the lug wrench doesn't.  Make sure to carry a lug wrench for the camper.
Post by: pinstriper on November 21, 2014, 11:54:27 AM
I dunno why I think this, as I haven't checked, but I was under the impression, or delusion, that the stabilizer jack wrench was the same size as the lugs.
I'll check this one of these days. I'm too lazy today.
Post by: spot1 on November 21, 2014, 12:13:04 PM
Carry a spare wheel/tire, too. Also carry a small 2 ton floor jack that works nicely on the CL axle.
[a href="http://s657.photobucket.com/user/vstromklr/media/2013/2014/IMG_3796_zps2b5f267b.jpg.html"]
[img style="max-width:100%;" src="http://i657.photobucket.com/albums/uu299/vstromklr/2013/2014/IMG_3796_zps2b5f267b.jpg"][/a]
Post by: runningwriter on November 23, 2014, 11:56:01 AM
Quote from: @pinstriper" source="/post/5235/thread" timestamp="1416585267I dunno why I think this, as I haven't checked, but I was under the impression, or delusion, that the stabilizer jack wrench was the same size as the lugs.
Our stabilizers are the non-jack type.  You may be correct.
Post by: pinstriper on November 23, 2014, 03:35:15 PM
Quote from: @dave" source="/post/5264/thread" timestamp="1416758161
I didn't know there was any other type. Ours is your basic scissors jack bolted to the bottom of the trailer box (not the frame).
Post by: runningwriter on November 25, 2014, 09:09:34 AM
Quote from: @pinstriper" source="/post/5267/thread" timestamp="1416771315[quote source="/post/5264/thread" timestamp="1416758161" author="@dave"]Our stabilizers are the non-jack type.  You may be correct.
Back in 2011, mine came with the kind that swing down and then, extend to reach the ground.
