Okay factory, here's one for you,
My 10.0 has plastic covering the tops of the bunk ends. This plastic has become unstable and is peeling off all over the exterior. It looks horrible. What is this and can I remove it? How do I clean off the remaining sticky adhesive if I do remove all the plastic? Also, since I will also have to re-caulk the edges, what is the recommended sealant?
I will post pix for the forum as soon as I can.
Thanks,
HP
Got a picture tonight. Not pretty...
[attachment id="349" thumbnail="1"]
Wow. I've never seen anything like this. Does it look like some sort of protective cover that should have been removed? All I can think of to try would be denatured alcohol or something like Goo Gone ( http://googone.com/Home.aspx )
Yes, it appears to be a plastic film over the aluminum. It reminds me of the plastic you see on a new guitar pick guard that gets peeled off when you buy the guitar. Once we're done camping for this season I am planning to remove it completely and try to clean it up. But I wanted to hear from someone in the company to let me know exactly what I'm dealing with. I will also have to re-caulk both bunk ends once I have the plastic off.
I think that plastic was meant to be removed, and I bet it peels right off. Why do you need to re-caulk both bunk ends after you remove that plastic?
The gray caulk is on top of the plastic. When I remove the plastic the caulk will come off with it. Also, the caulk is already coming off in places due to not completely adhering to the plastic.
Also, in places where the plastic is already coming off there is some sort of sticky residue. I will have to clean this off after peeling the rest of the plastic off.
[quote source="/post/3470/thread" timestamp="1410345536" author="@henwilli"]The gray caulk is on top of the plastic. When I remove the plastic the caulk will come off with it. Also, the caulk is already coming off in places due to not completely adhering to the plastic. [/quote]They caulked OVER the plastic? That is amazing. Hope you can get the sticky stuff cleaned off OK.
[quote source="/post/3473/thread" timestamp="1410349190" author="@djsamuel"][quote source="/post/3470/thread" timestamp="1410345536" author="@henwilli"]The gray caulk is on top of the plastic. When I remove the plastic the caulk will come off with it. Also, the caulk is already coming off in places due to not completely adhering to the plastic. [/quote]They caulked OVER the plastic? That is amazing. Hope you can get the sticky stuff cleaned off OK. [/quote][font size="3"]If this is true it's crazy and inexcusable. Must have been Jimmy Jones' first, and hopefully last, day on the assembly line. Where the hell was supervision?
Well, I'm going to reserve judgement until I hear from the factory in this, the "Ask the factory", forum. If I get no response it will speak volumes.
I think the plastic should have been removed by the dealer. When I got my 14XLP the tarp had melted itself to the top (bottom of the bunks) in multiple places, leaving a nasty residue (see my previous post). I finally got it off with enamel reducer but that also took the paint in several places (it was my last resort). So I can tell you that the bunk bottoms are painted aluminum. I plan to repaint mine in a few weeks when the humidity calms down.
Yes m0brando, your pictures are very similar to what I've been seeing.
My tarp is also fried by the heat and will be replaced this winter after I take a few more fall mountain trips. The tarp is disintegrating in my hands whenever I unroll it. I attributed this to the scorching Georgia summer heat and it probably had something to do with the plastic bubbling up.
Lesson learned - Keep the camper in the garage and leave the cars out in the sun.
