Ask the Factory => Ask the factory => Topic started by: drdave on September 01, 2014, 07:52:35 PM
Title: Bumper bike rack/cargo mount as an accessory
Post by: drdave on September 01, 2014, 07:52:35 PM
After reading another thread about an owner having his bumper tear off due to a bumper mount bike rack I am very concerned about mounting my family's bikes on the bumper.   I'd like to see a factory option and/or after-market purchase bolt-on 2" receiver type mount with added support as a LL authorized aftermarket option.    If anyone has ideas on how to beef up the standard curt add-on bumper mount with brackets or another method I am all ears!
Post by: charliem on September 01, 2014, 08:36:27 PM
[font size="3"]The factory bumper is very iffy for bicycles. The torque placed on the single 2x4 AL bumper and welds by the bikes can cause failure. My solution is shown [a href="http://livinlite-owners.com/thread/14/bike-rack-21rbs"]HERE[/a], but other solutions may be possible. I ordered the custom bumper enhancement from the factory as the CL was being built. The bike rack is extremely rigid and strong; I can stand on the rack with no perceived flexing. The bikes, visible in the rear view camera, show no signs of bouncing. However, the enhancement must be applied at the factory. Possibly the additional tube could be welded on afterwards, but caution and expertise would be required.
Post by: drdave on September 01, 2014, 09:13:49 PM
I like that simple fix.  Perhaps your doubling up can be an after-the-fact solution with some added tabs on each end of the added bumper tube section.   Maybe LL can offer a "slip on" 2x4 tube brace that doubles up the bumper between the the frame-rails as you have done, but have "I beam" like tabs that lock on the frame rails then a typical 4"x 4" bumper hitch can be bolted on over both the original bumper and the added 2x4 bracket as you have done.  I assume the frame rails are all the same distance apart on all the 7ft wide CL models so maybe it could be a mass produced item?
Post by: charliem on September 01, 2014, 10:54:28 PM
[font size="3"]I'm not sure what you're thinking with "added tabs", "slip on tube brace", and "I-beam like tabs." The second 2x4 tube must be welded to both frame members and the original bumper as shown in the drawing to achieve the strength. Any bolt on addition will not share the loads with the existing welds and can lead to failure. And secondary welding on the existing bumper would require removing the tail lights and wiring to prevent heat damage. As for the rail spacing, I suspect they are the same on all CLs, but I don't know for sure.
Post by: drdave on November 18, 2015, 08:29:33 PM
Sorry for reviving a dead thread.    I found this on etrailer as well as other options intended for 5th wheel frames and motorhomes.   I'm wondering if this, or another similar model could be mated to a LL frame?
http://www.etrailer.com/Specialty-Trailer-Hitches/Curt/13703.html
Post by: daplumbr on November 18, 2015, 09:29:23 PM
No thread is dead if there's interest! I measured the distance from the frame on my 16TBS to the ground in the rear and then using the measurements in the etrailer listing, I figured I would only have 7 inches of clearance from the bottom of that hitch to the ground. So, this particular one would probably not work on a 16TBS. However, the concept may have merit, especially if an extra brace were run up to the bumper right above the receiver. Could be the basis for some custom work? I would love to mount bikes on the rear using my hitch mount rack, but can't with my current 2X3 side frames and single 2X4 bumper.
Post by: drdave on November 18, 2015, 09:48:19 PM
Here's the link for all the options:
http://www.etrailer.com/dept-pg-Specialty_Trailer_Hitches-sf-RV_Hitch.aspx
Post by: daplumbr on November 18, 2015, 11:53:21 PM
Hmmm.....some of these are intriguing. I need to go investigate the trailer framing a bit more. May be some better ideas than the 1200 zip ties I was going to use for the rack  ;)
Post by: charliem on November 19, 2015, 09:34:27 AM
[quote source="/post/16668/thread" timestamp="1447892973" author="@tlbones"]Sorry for reviving a dead thread.    I found this on etrailer as well as other options intended for 5th wheel frames and motorhomes.   I'm wondering if this, or another similar model could be mated to a LL frame?
[/quote][font size="3"]I think bad news if you follow the video. Lots of holes drilled in the frame including huge (1+inch) access holes. If you bolt something on it should be clamped or U-bolted. [/font]
Post by: spot1 on November 19, 2015, 10:20:08 AM
Charlie, Since your first post before the forum name change, your link now goes to the the general forum. Would like to see your solution, if possible, Thanks.
Used two different methods of bike transport, between TV & Camper, currently transporting bikes in the camper.
Downside of towing between campers is possible clearance issues, can't get in rear of TV while bikes are transported, bikes are outside, and additional tongue weight.
Downside of transporting in the camper, no room in the CL 11 while bikes are being transported, plywood board is stored under the camper when not in use getting dirty and wet.
Upside of transporting bikes in the camper, they are out of the elements.
[a href="http://s657.photobucket.com/user/vstromklr/media/2013/IMG_0453_zps1800b8eb.jpg.html"]
(http://i657.photobucket.com/albums/uu299/vstromklr/2013/IMG_0453_zps1800b8eb.jpg)
(http://i657.photobucket.com/albums/uu299/vstromklr/2013/IMG_0452_zps9e3ec99c.jpg)
(http://i657.photobucket.com/albums/uu299/vstromklr/2013/IMG_0136_zps7561f2b9.jpg)
(http://i657.photobucket.com/albums/uu299/vstromklr/2013/IMG_1321_zps407a00cd.jpg)
(http://i657.photobucket.com/albums/uu299/vstromklr/2013/2014/IMG_5512_zpsb9e625d4.jpg)
Post by: charliem on November 19, 2015, 10:56:03 AM
[quote timestamp="1447942808" source="/post/16686/thread" author="@exploringcarolina"]Charlie, Since your first post before the forum name change, your link now goes to the the general forum. Would like to see your solution, if possible, Thanks.
[/quote]OK. I updated/corrected the previous link, but here it is again: [a href="http://livinlite-owners.com/thread/14/bike-rack-21rbs"]http://livinlite-owners.com/thread/14/bike-rack-21rbs[/a]
I also used the Swagman with a slightly different hitch configuration with my old RPOD/Pilot combination. There I mounted the bikes on the back of the Pilot, between TV and TT and it worked well. You're right about the clearance and rear compartment access, but it worked well for me.  I'll look for a picture.
Post by: spot1 on November 19, 2015, 10:58:57 AM
Charlie, Thanks for the info. Looks like a good solution!!!!!
Post by: charliem on November 19, 2015, 11:11:27 AM
[font size="3"]Picture of Swagman bike rack I used previously between TT and TV.  It requires an extended hitch shank that I didn't want to use with the 21RBS. My loaded 21RBS measures 525# tongue weight so I wanted it as close to the Tacoma as possible. This approach m[/font][font size="3"]ight work on the lighter CL11/Tacoma combo with proper attention to clearance and turning radii, but you wouldn't be able to lower the tail gate.[/font][font size="3"]
Presently I carry the bikes on the back of the trailer on the road, but can swap the carrier to the back of the Tacoma after I disco the trailer. Nice for hauling the bikes around to local biking venues.
[attachment id="959" thumbnail="1"]
Post by: drdave on November 19, 2015, 07:19:21 PM
[quote source="/post/16684/thread" timestamp="1447940067" author="@charliem"][quote source="/post/16668/thread" timestamp="1447892973" author="@tlbones"]Sorry for reviving a dead thread.    I found this on etrailer as well as other options intended for 5th wheel frames and motorhomes.   I'm wondering if this, or another similar model could be mated to a LL frame?
[/quote]  I agree following the instructions to the letter is not a great idea with an aluminum frame, but I'm thinking a select amount of appropriately sized/placed self tapping screws in combination with ubolts or clamps as you suggest would be sufficient for a bike rack.  YMMV.
