Camplite => Camplite Travel Trailers => Topic started by: shark24 on June 03, 2016, 11:52:05 PM
Title: Torque bits
Post by: shark24 on June 03, 2016, 11:52:05 PM
Anyone know what size the star looking torque bits are that fit the exterior screws and/or interior floor table bracket. I have one bit but it is the wrong size. Going to Lowe's to try to find one tomorrow but if anyone knows what size or number I need to buy would be very helpful.
Thank you
Title: Torque bits
Post by: franks97224 on June 03, 2016, 11:58:33 PM
[quote timestamp="1465008725" author="@shark24" source="/post/21895/thread"]Anyone know what size the star looking torque bits are that fit the exterior screws and/or interior floor table bracket. I have one bit but it is the wrong size. Going to Lowe's to try to find one tomorrow but if anyone knows what size or number I need to buy would be very helpful.
Thank you[/quote]I don't think you can find a star pattern to fit but a square S2 works on mine.
Title: Torque bits
Post by: shark24 on June 04, 2016, 12:03:24 AM
so you think i can go to lowe's and ask for a square S2 bit and they will have this?
thank you
Title: Torque bits
Post by: franks97224 on June 04, 2016, 12:29:11 AM
[quote timestamp="1465009404" source="/post/21898/thread" author="@shark24"]so you think i can go to lowe's and ask for a square S2 bit and they will have this?
thank you[/quote]It is a pretty common bit for deck screws so they should have it. I found some at a True Value.
Title: Torque bits
Post by: billmoore on June 04, 2016, 12:45:29 AM
Has anyone tried a Spider bit? They are 8 point like the screws in our LivinLite, but it is impossible to tell from pictures if they are the right size. Looks like Spider is a single size...
http://www.amazon.com/FastenMaster-FMSPIDER3-2PK-HeadLOK-Spider-Driver/dp/B0041NM7NA
Title: Torque bits
Post by: admin on June 04, 2016, 02:12:38 AM
The screws are definitely square drive S2 bits. I can't say one way or the other for the spider ones though.
Title: Torque bits
Post by: charliem on June 04, 2016, 09:16:26 AM
[font size="3"]Technically the screws are called double square. They are a modification of the square or Robertson head, but adapted for easier engagement. The same effect as going from a 6 point socket to a 12 point socket, with the same increased roundoff potential. As mentioned, a #2 or S2 (Red) square bit works and is readily available.
[a href="https://en.wikipedia.org/wiki/List_of_screw_drives#Double-square"]https://en.wikipedia.org/wiki/List_of_screw_drives#Double-square[/a]
[a href="https://en.wikipedia.org/wiki/List_of_screw_drives"]https://en.wikipedia.org/wiki/List_of_screw_drives[/a]
Title: Torque bits
Post by: shark24 on June 04, 2016, 11:45:18 AM
When I get the screws out do I need to fill the holes in with anything? I will be removing the table bracket.
Title: Torque bits
Post by: charliem on June 04, 2016, 12:24:01 PM
[font size="3"]Depends on where the screws are. Outside, definitely fill with silicone or Dicor caulking. The table is your choice, but it doesn't hurt to fill with silicone or Dicor caulk. If the holes are exposed it will have a minimal effect on air/dust infiltration. If you have the stock uncovered aluminum plank floor it's not worth the effort.
Title: Torque bits
Post by: shark24 on June 04, 2016, 04:54:59 PM
Worked like a charm! Awesome thanks!
