Ask the Factory => Ask the factory => Topic started by: shortcircuit on March 02, 2016, 05:34:34 PM
Title: flexible hose on Camplite fresh water system
Post by: shortcircuit on March 02, 2016, 05:34:34 PM
[font face="comic sans ms" size="3"]Hello Factory,
I want to purchase about 10 ft. of the flexible hose used on our Camplite 14DBS fresh water system to install a winterizing valve. The Valtera part number is W01-2105NSF. It is 1/2" I.D. x 5/8" O.D. It is 1/16" wall thickness not the standard 1/8" wall as in most stores. It is more flexible. I can't find it in any store locally, and online I would have to buy 100ft. roll.
Can someone give me contact info and how to buy it?
Thanks,
Shortcircuit[/font]
Post by: christianm on March 03, 2016, 12:15:00 PM
Hi Shortcircuit!
For any parts orders, you'll need to contact Jack Filley at  j.filley@livinlite.com. He runs out parts department and would be able to help you track down whatever you need.
Hope this helps!
Christian
Post by: david on March 03, 2016, 04:07:27 PM
Just go to any big box store and buy 10' of the fiber reinforced clear vinyl hose, sized to slip over the hose barbs. Should work fine.
Post by: blairh on March 03, 2016, 04:42:18 PM
Quote from: @shortcircuit" source="/post/19103/thread" timestamp="1456954474[font size="3" face="comic sans ms"]Hello Factory,
Thanks,
Shortcircuit[/font]
Visit your local RV dealer, if you can't find any at the local hardware store. Its a common hose that is used in RVs, most dealer will have stock or can get it.
