Camplite => Camplite Travel Trailers => Topic started by: charliem on December 16, 2015, 06:45:40 PM
Title: Camplite Battery Charging
Post by: charliem on December 16, 2015, 06:45:40 PM
[font size="3"]As an experiment I compared different methods of battery charging on my 21RBS. The batteries were two 6V golfers in series. I started with the batteries at 11.85V open circuit at 68F after resting *, or about 35% SOC. Using the onboard converter plugged in to shore power the initial current measured 38+ Amps and quickly dropped off. Using 20 ft. #4AWG copper jumper cables from my Tacoma the current initially measured 69A and quickly dropped to 50+ Amps. At 35 minutes it had dropped to 28A at 13.03V. After 1 hour I measured 23A at 13.03V.  Even at 23A I measured 0.3V drop in the 20 ft. #4 copper jumper cables. Charging current is very sensitive to voltage so every 0.1 volt contributes to reduced charging current. Cheap jumper cables won't cut it. After a 30 minute resting period I measured 12.35V, indicating 70% SOC.
Reconnecting the truck for an additional 30 minutes got it to 12.46V resting or 80% SOC. A previous test indicated I used about 30 AH/day with moderate furnace use, lights,  and heavy use of a watt sucking laptop. Thus a 1 hour recharge period every other day would go a long way to extending my dry camping time. The only unanswered question is the time required to recharge to 80%. The jumper cables supplied a higher current, but the onboard converter eventually charges at a higher voltage, 14.4 vs 13.3 for the truck.
Certainly the onboard converter is best where shore power is available, but the jumper cable method provides a viable recharge if shore power or generator are not available. The truck is a whole lot quieter and more convenient than a generator. No gas cans or heavy generators to haul. The truck only burns ½ GPH at idle so just make sure you have a full tank when setting up.
* Resting overnight with only the 170 mA residual load on the battery.
As an aside I tried plugging the Camplite power cord into the 400W inverter built into the Tacoma. The current measured only 3.6A and the microwave display didn't light at all. This is consistent with previous attempts at using the truck inverter to run the CL. Apparently the CL doesn't like the waveform of truck inverter (probably MSW) or the load (38A x 12V) crowbars the inverter. Further investigation is required. If it's because the load is exceeding the 400W rating it's not really useful. EDIT: Turns out I'd left the electric side of the water heater on. That will kill a 400W inverter every time  :'(
Post by: joanne on December 16, 2015, 10:11:55 PM
This is the first time I've seen real numbers on using jumper cables from a running vehicle. I've done that in a pinch, but had no idea that it was reasonably effective.
Good info. Thanks.
Post by: leslie on December 16, 2015, 10:43:24 PM
Maybe I have missed something. I thought using the 7-pin connector and running the engine of the tow vehicle, whether running down the road or just idling, was a quicker way to charge AGM batteries than using jumper cables.
We have been able to bring our batteries back up with about 4 -5 hours driving. We had everything turned off in the trailer except for the refrigerator running on propane, and, of course, the blue light on the radio was on.
Post by: charliem on December 16, 2015, 10:57:55 PM
[font size="3"]Charging from the 7 pin TV connector is extremely ineffective. This is due to the small wire used between the TV battery and the 7 pin connector and the small wire from the 7 pin to the TT battery. At best it is only able to maintain a charge; maybe recharge slightly. However, given enough time (4-5 hrs) it may restore some charge. If nothing else is running you may get 10 Amps to the TT battery. Notice the 0.3V drop I measured with #4AWG wire. The TV and TT are wired with #10AWG at best; sometimes even smaller. The jumper cable, although a bit inconvenient, is the most effective short of a high powered plug in battery charger. My intent was to deal with the times when I was camped for several days without any shore power hook up. I don't like noisy messy generators and the TV with its engine, muffler, and gas tank is coming along anyway  ;)    .
BTW that blue light can be turned off from the menu.
Post by: pinstriper on December 16, 2015, 11:08:32 PM
Or, remove the faceplate and put it in the cabinet. Presto ! No more blue light.
Post by: leslie on December 16, 2015, 11:27:02 PM
I asked my husband to remove that faceplate, because I hate that bright blue light, but he didn't want to touch it. I didn't know I could turn it off from the menu. I will have to give that another look.
My youngest son is a computer and electronic geek. If all else fails, when we visit him in Florida, I will ask him to help me out.
About recharging the batteries using the 7-pin connector - I really don't know how low the batteries got. My husband checked them, said they were low. We drove for 5 hours. He checked again - said they were fine. Now I am wondering just how much confidence I should have in that connector.
Post by: charliem on December 16, 2015, 11:43:50 PM
[font size="3"]First the blue light. The light will be on while you're using either the radio or the external input. If the radio is on the blue light will be on. When you turn the radio off by holding the mute button down the clock will remain in blue. This can be inhibited from the menu, but it's a bit elusive. Isn't it always? If I'm plugged in I turn off the microwave at the circuit breaker at night. I don't like green lights either.
Now the battery charging. Others have noted the 10 Amp number, but I have not measured it. It's highly dependent on the TV. But let's assume the 10 Amp number is good. As I stated my daily use was about 30 Amp-Hours per day so it would take three hours of driving to recover. If you've been running on battery for three days as I did last week it would take 9 hours of driving. That's a long day for us old folks. Four days on battery and you're in trouble.
Post by: leslie on December 17, 2015, 12:53:31 AM
That microwave light annoys me too. I like darkness at night which is just one of the reasons why I want to go boondocking.
After having a house way out in the country for 34 years, with the only night light coming from the moon, I really miss not seeing stars when I walk the dogs at night, not to mention not having a dark bedroom at night. Now, enough light filters in through the curtains that no night light is necessary. This is in our apartment. Some campgrounds let in a lot of light through the window in the door. I am seriously thinking about a window cover for the entry door.
Post by: pinstriper on December 17, 2015, 12:59:07 AM
[quote source="/post/17199/thread" author="@leslie" timestamp="1450322822"]I asked my husband to remove that faceplate, because I hate that bright blue light, but he didn't want to touch it. I didn't know I could turn it off from the menu. I will have to give that another look.
[/quote]It's easy. All you need is a #5 torx driver and  a slotted screwdriver (that's a "regular" as opposed to "phillips"). 7 small bolts and a little prying with the flat of the screwdriver. 15 minutes tops, and no more blue light.
Post by: leslie on December 17, 2015, 01:03:25 AM
Back to the thread - Louisville RV does some work for me - filling propane, repacking the bearings, etc. They tell me I can completely discharge my AGM batteries and they will come back just fine if I tow the trailer for a trip or plug in when I get to a campground. They say that is what the AGM batteries are made for.
So far, we have only gone one day at a time on battery power. We plan to work ourselves up to 3 or 4 days on battery power. So long as we are careful, I thought it would be possible to go 5 or 6 days on battery before we have to drive off and recharge.
We are looking - OK, I am pushing - for 5 days on battery power in Quartzsite AZ for January 2017. No generator.
Post by: pinstriper on December 17, 2015, 01:22:20 AM
Quote from: @leslie" source="/post/17203/thread" timestamp="1450328605Back to the thread - Louisville RV does some work for me - filling propane, repacking the bearings, etc. They tell me I can completely discharge my AGM batteries and they will come back just fine if I tow the trailer for a trip or plug in when I get to a campground. They say that is what the AGM batteries are made for.
We got a 75w portable solar panel "free" when we bought our trailer. Looks like a large briefcase and folds out, aligator clips to + and -. Pretty simple, and I used it to top off the battery once when the barn had a circuit issue.
I have no idea how fast it puts how much back on the battery, but I would think such a thing would be a good addition if boondocking in a sunny place like AZ. Way better than nothing at all, anyway. Very compact and easy to bring along.
Post by: mitch on December 17, 2015, 08:46:51 AM
Leslie, what's your battery setup (how many Amp Hours)?  Five days is a pretty long time.
Post by: whoofit on December 17, 2015, 09:56:15 AM
Quote from: @leslie" source="/post/17203/thread" timestamp="1450328605They tell me I can completely discharge my AGM batteries and they will come back just fine if I tow the trailer for a trip or plug in when I get to a campground. They say that is what the AGM batteries are made for.
AGM batteries can take a beating but suggesting they can be brought down dead as a door knob and "will come back just fine" is a risky statement. One of the several benefits of AGMs is their deeper Depth Of Discharge. Better than conventional wet lead acid but still can be damaged real good going full dead.
Leslie, I suggest you have them install a battery monitor. One that will tell you what your SOC (state of charge) is. Those will measure the CE (consumed energy) at any given moment. It will tell you how many amps you are drawing at the moment. Some will calculate TTG (time to go) at your current level of discharge (though this is not a very accurate calculation just a reference).
On the flip side, they can measure the amount of energy you have put back into the battery during or after charging and not be tricked by the "skin effect" that plagues most folks when using a simple voltmeter. Most folks say "look, it's full" long before it really is. In the inverse most folks think their battery is discharged when it isn't because of loads present on the battery. A good battery monitor like a Victron will sort through all the BS.
But a word of caution, the Victron is another Blue Light...
Post by: charliem on December 17, 2015, 10:09:44 AM
[font size="3"]Leslie,
I will also add my cautions on total discharge. Dealers sound like thy are knowledgeable, but seldom are. I refer you to Battery University at: [a href="http://batteryuniversity.com/learn/article/absorbent_glass_mat_agm"]http://batteryuniversity.com/learn/article/absorbent_glass_mat_agm[/a]  .
A key quote from the article is:
"The leading advantages of AGM are a charge that is up to five times faster than the flooded version, and the ability to deep cycle. AGM offers a depth-of-discharge of 80 percent; the flooded, on the other hand, is specified at 50 percent DoD to attain the same cycle life."
80% discharge, not 100%. The note on faster recharge is also true for AGMs, but only if the charging system can support it. Generally not true for TVs with 7 pin connectors.
Post by: david on December 17, 2015, 10:27:16 AM
Ok, here is some techie/geeky stuff:
I once measured 7 amps of charge coming from my TV's connector when the batteries were down but not that down, maybe down 30%. Since batteries take more voltage to charge at the same current the more they get charged, a 50% discharged battery might take 13V to charge at 20 amps of current. But as Charlie notes the TV/Trailer is wired with 10 gauge wire, so there is a very significant voltage drop at 20 amps, about a volt. Since the TV's alternator will only put out about 13.5 volts, there is not enough voltage at the battery terminals- 13.5-1 = 12.5 to supply 20 amps. So it supplies less and the voltage drop is less and it balances, maybe a 10 amps.
So, due to the fixed voltage of the alternator and the voltage drop in the wire, a 90% discharged battery (not a good idea, even with an AGM) might see 20 amps as you start charging. As it reaches 50% it might see 10 amps and at 20% it will probably be down to less than 5 amps.
The bigger wire in the jumper cable helps a lot with the voltage drop as Charlie noted, but does nothing for the fixed output voltage of the alternator. It might take several hours of TV charging with a jumper cable to add 100 amp hours to a pair of 50% discharged golf cart batteries.
Finally, you have to wait a long time to use the voltage vs state of charge charts accurately, at least 4 hours of total resting- no loads and no charging. This was proved by another very geeky boater friend who measured his battery voltage every hour for 24 hours. It didn't begin to stabilize until after 4 hours and dropped another tenth of a volt at 12 hours. A tenth of a volt difference is approximately 10% SOC difference and at after only an hour it was off three tenths of a volt or 30%..
Post by: whoofit on December 17, 2015, 11:41:28 AM
So, you can see the complexity in properly charging a battery. When you add more than one battery to create a bank you now have to factor in the possibility of equalization that makes it all the more complicated. Equalization is not something regularly discussed in the RV world. In solar it is harped upon and people are taken to task for not doing it religiously. It is not needed as often in the RV world as the battery banks are less complex with fewer members but it will still need to be done every now and then, out of circuit, by a separate charging device.
Makes a lot of RVers go straight to genny.
That resting period David mentioned above is what I referred to as "skin effect". A good battery monitor eliminates this. As much as I enjoy testing and tinkering, as you can see by the others' posts above, it takes knowledge, time, tools and dedication with look up tables and general battery smarts bordering on a EE degree to replace a well designed smart battery monitor. At least until you know the trailer by heart and providing your battery bank is not aged significantly., and you have accounted for temperature variation...and on and on...
IF you are going to approach the boundaries of your battery bank's capacity, and want to trust all will be well, with no worries, and still be able to relax and enjoy the trip, then a good quality battery monitor is money well spent. I often compare it to a fuel gauge on the TV... nice to have, right?
Post by: david on December 17, 2015, 12:31:41 PM
I am a big fan of battery monitors. They do have to be set up right to work well with the amp hour capacity plugged in correctly. I had one on the first of four boats and one prior RV. But today I don't need it. Why?
I have a very simple one battery system. I can check the state of charge quite accurately with a specific gravity meter since I think I have a true deep cycle battery with removable water caps. For the first half dozen nights camping (not consecutive necessarily) after I got the trailer, I watched the SOC after a day, then two days and finally three. I learned that I was above 50% (the point at which you start harming a flooded cell battery) until well into the third day. I also learned that 4-5 hours of driving would take a 25% discharged battery back to near full charge.
So, with those two facts in mind, I have pretty much forgotten about it. I never camp more than two days at one place and if I at least drive a couple of hours to the second place I put enough charge back in to be above 50% at the end of the third day. Then I drive home and take the battery out and put it on a trickle charger until next time.
If you don't camp like me, and also don't camp where plug in power is available, a battery monitor might be useful. But I suspect that the great majority of LL campers don't camp for three straight days with no plug in power. If they do, then the addition of a pair of golf cart batteries (about triple the AH capacity of my single battery) will extend the no worries period to about a week of consecutive camping in one spot.
Post by: whoofit on December 17, 2015, 01:02:36 PM
Yes, that's just it. If you are not going to be bucking the limits of the battery then all is well. In Leslie's example she is looking for five days with who knows how much demand. It's hard enough to profile without measuring and with the advice she received regarding fully discharging AGMs this could easily spell disaster. A pair of AGMs cost a significant amount and well written warranties might just make that an out of pocket learning experience.
I went from one Group24 to one Group30 AGM then moved to two GC2's in my short ownership of less than one year. The Group24 was a bum battery straight from the dealer. The Group30 went to my son in law for his NFL tailgating addiction. The 2xGC2's are the type of power we need for the long winter nights. I am quite embarrassed to admit to our winter usage. Anything less than 2xGC2's are just inadequate in the winter but in the summer they will be overkill. Closely monitoring is much easier with the BM as our demand varies greatly.
Post by: billmoore on December 17, 2015, 01:21:17 PM
[quote source="/post/17213/thread" timestamp="1450366888" author="@whoofit"]Makes a lot of RVers go straight to genny.
[/quote]LOL... I have an EE degree, and still went straight to genny!
Post by: billmoore on December 17, 2015, 01:28:26 PM
We rarely camp where there is power, so for us it was a no-brainer to just go with a generator. We've found that running the generator 30 minutes in the morning (which lets us use the espresso maker and microwave) and another 30 minutes around supper time keeps the batteries topped off without being too annoying to the neighbors (if there are any). We've gone 5 days like this with no problem.
Our generator is this one:
http://www.costco.com/Champion-2%2c800W-Running--3%2c100W-Peak-Digital-Inverter-Gas-Generator-%28CARB-50-State-compliant%29.product.100139466.html
$700 at Costco, and it is reasonably quiet at 58 Dba - you will hear it, but it isn't obnoxious like an open frame generator...
Post by: whoofit on December 17, 2015, 01:44:45 PM
[quote timestamp="1450372877" author="@billmoore" source="/post/17217/thread"]
Quote from: @whoofit" source="/post/17213/thread" timestamp="1450366888Makes a lot of RVers go straight to genny.
[/quote]We started bringing along the genny when we got the new TV and could swing the extra weight. Have not used it camping yet but figured why not? It just sits there at home looking all useless if we don't.
We have the Eu2000i with the tri fuel conversion. A lot of expense for an item we never really use. Expect to use it more next year with more substantial trips to more remote places like you do..
Post by: david on December 17, 2015, 01:55:33 PM
Billmore:
You have already gone the generator route, so this is for those who are thinking about it. This is an alternative:
Most summertime campers, use about 15-20 amp hours each day of camping. The single Group 24 or 27 battery typically delivered with a LL is rated at 60-75 amp hours and weighs 40-50 lbs. This battery will last for 2-3 days and stay above the recommended floor of 50% discharging. If you never camp for more than two days consecutively, you don't need anything else.
If you replace the single battery with a pair of golf cart batteries rated at 220 AH then your capacity triples and you can go 5 to 7 days and stay above 50%.
Frankly I would rather invest $300 in a battery box, some aluminum cross supports, two GC batteries and some wiring and never have to think about it again, much less run an annoying generator.
The generator costs more, uses gasoline which you have to store and carry, weighs about as much as the additional batteries that replace it, ..... What isn't to like. Well, I don't have a good answer for the expresso maker ;-).
Post by: leslie on December 17, 2015, 01:58:04 PM
My eyes are glazing over. I can see the advantage of an SOC. My husband is an EE. I am going to have him read this thread, and the other threads about batteries and let him decide. Anything else he needs to consider?
This summer we are going to take baby steps with boondocking, so we figure out how to make water and batteries last.
Post by: billmoore on December 17, 2015, 02:00:47 PM
Good points David! For us the need to carry gasoline is a non-issue since we have a toy hauler and need gas for the toys anyway.
One other plus to the generator - you can run the AC.
We have only had to do this once, in a hot spell last summer where temps were topping 100F. When we got the trailer, I thought we'd never use it living here in the PNW where summer temps rarely exceed 80, but last summer saw many 90+ days and a few 100+...
Post by: whoofit on December 17, 2015, 02:23:46 PM
There really is no substitute for the genny if you intend to use the trailer at it's fullest without being grid tied is there? Every experience differs. We came from a tent/tarp/hammock to a seasonal seashore site with an old TT, to the CL for more mobility. We do fall asleep to movies, stream video and music, run a 4G booster and run the AC sometimes too.
If not, we could do near as well in a tent. It's nice to be able to indulge a bit when we feel like it. So far it has happened mostly on grid.
Post by: daplumbr on December 17, 2015, 02:58:49 PM
Here are a great set of articles on deep cycle batteries.
http://www.solar-electric.com/deep-cycle-battery-information-faq.html/
Post by: easwen on June 18, 2016, 12:13:33 PM
Anyone convert their trailer to Photo voltaic power?
Post by: daplumbr on June 18, 2016, 10:04:36 PM
Several folks have installed or use solar panels to help charge batteries off-line. Run a search using the term solar and many threads will pop up. Of course I'm sure you know you can't run an RV air conditioner on solar so you can't convert entirely to photovoltaic if you need air conditioning!
Post by: drake on June 19, 2016, 01:30:43 AM
We went with this setup which we found from recommendations on here.
https://www.amazon.com/gp/aw/d/B00HR8YNK6/ref=mp_s_a_1_3?qid=1466310525&sr=8-3&pi=SY200_QL40&keywords=renogy+solar+panel+kit&dpPl=1&dpID=51reDjTwDRL&ref=plSrch
Haven't used it camping yet, but tested it in the yard and it's pretty awesome.
Post by: spot1 on June 19, 2016, 10:40:25 AM
One guy on the Oliver forum with factory installed solar panels and 2000W inverter figured out how to run his 13.5K ac with on-board batteries for a few hours while at rest areas.
http://olivertraveltrailers.com/topic/ac-running-on-batteries/
Post by: daplumbr on June 19, 2016, 12:24:30 PM
[quote timestamp="1466343625" source="/post/22325/thread" author="@exploringcarolina"]One guy on the Oliver forum with factory installed solar panels and 2000W inverter figured out how to run his 13.5K ac with on-board batteries for a few hours while at rest areas.
[/quote]Very cool, so to speak. I'll look into that Atwood AC if/when we give up on the noisy 9.2K Mach 8.
Post by: spot1 on June 19, 2016, 12:36:18 PM
[quote source="/post/22327/thread" author="@sandroad" timestamp="1466349870"][quote timestamp="1466343625" source="/post/22325/thread" author="@exploringcarolina"]One guy on the Oliver forum with factory installed solar panels and 2000W inverter figured out how to run his 13.5K ac with on-board batteries for a few hours while at rest areas.
[/quote]Very cool, so to speak. I'll look into that Atwood AC if/when we give up on the noisy 9.2K Mach 8.[/quote]Like his AC system too, he has the Blue Sky Solar package, we don't have that system on our Ollie. We have a 2400W Yamaha gen-set when away from shore power.
Merlin,
Our Daughter and family are being transferred from MI back to the Carolinas, so not sure when we will be back in your area again.
Please let us know if you will be camping in the SE and we will try to visit or camp again!
Post by: david on June 19, 2016, 01:07:32 PM
You can run the A/C for a short period using an inverter, but you need a big inverter, and a large battery bank to do it. His A/C draws 12.5 amps AC. That will take more than 130 amps DC input to the inverter. That will take a pair of golf cart batteries down to 50% state of charge in less than an hour.
Post by: spot1 on June 19, 2016, 02:48:57 PM
Believe he has 320W roof mounted solar panels with 2000W inverter. He might have had 4 Trojan T-105 or 4 Trojan AH T105-AGM batteries during the test.
Repeating what trumpetguy indicated: Running 12.5 AMPs is high from his actual experience with his unit. AC running is 4.5 to 5.5 amps.
This is very interesting for me.
Post by: daplumbr on June 19, 2016, 09:07:22 PM
Quote from: @exploringcarolina" source="/post/22328/thread" timestamp="1466350578[quote source="/post/22327/thread" timestamp="1466349870" author="@sandroad"]Very cool, so to speak. I'll look into that Atwood AC if/when we give up on the noisy 9.2K Mach 8.
Merlin,
[/quote]I hope the job transfer goes well. I'm sure we'll be heading to the SE sometime. The Okefenokee (Stephen Foster State Park) in GA is one of our favorite places in the winter.
Post by: silverfox on August 24, 2016, 10:19:20 AM
Question's...I ran an underground 30AMP service to my trailer where I park it in my backyard. I have been keeping it plugged in between camping trips all summer. My wife leaves some food items in fridge between trips so I leave the frig on the AC setting except when towing when it switches to propane. Am I damaging my Interstate Deep Cycle Battery (provided by the dealer) or my charging system for that matter by keeping it hooked up to AC power for most of the summer? Seeing that we're on the subject.....I'm thinking of disconnecting my battery from trailer, leaving it in place and using my trickle charger to maintain charge for the winter, or will the rv charging unit do the same thing for me? Any thoughts or suggestions appreciated. Thanks
Post by: admin on August 24, 2016, 12:35:08 PM
The on board charger controller is multi stage so it should kick into float mode when the battery is full. It shouldn't harm it at all.
Post by: fasteddieb on August 24, 2016, 01:03:13 PM
I keep our 21BHS plugged into our 30A service whenever it's at home.
Our original battery is coming up on 3 years old and has not seemed to suffer any ill effects from that practice. We now have that battery and our newer rear battery wired in parallel and they both seem to be charging properly.
Post by: daplumbr on August 24, 2016, 02:46:06 PM
[quote source="/post/24105/thread" timestamp="1472044760" author="@silverfox"]Question's...I ran an underground 30AMP service to my trailer where I park it in my backyard. I have been keeping it plugged in between camping trips all summer. My wife leaves some food items in fridge between trips so I leave the frig on the AC setting except when towing when it switches to propane. Am I damaging my Interstate Deep Cycle Battery (provided by the dealer) or my charging system for that matter by keeping it hooked up to AC power for most of the summer? Seeing that we're on the subject.....I'm thinking of disconnecting my battery from trailer, leaving it in place and using my trickle charger to maintain charge for the winter, or will the rv charging unit do the same thing for me? Any thoughts or suggestions appreciated. Thanks[/quote]The electrics will be fine leaving the camper plugged in all the time, but you'll have to defrost the fridge once in a while  ;) .  However, the absorption refrigerator is not very efficient when running on AC (it uses resistance heating to run the cycle), so your electric bill may see some effect. It is not at all like the compressor refrigerator in your house that likely has extremely efficient energy usage.
Post by: silverfox on August 24, 2016, 08:53:22 PM
Thank you Gentlemen, that's just what I wanted to here. Except of course the part about the extra energy use. I just today installed a Dometic fan kit that clips on the fins inside my fridg. It's supposed to help with frost and comes with an on off switch. It also has a cool blue led light that illuminates the inside of fridge with seperate on off switch. Tomorrow I install another fan kit in the rear of the fridg to exhaust warm air build up. It has a thermo switch so it will only turn on when temp in rear of fridge reaches 130. The fans don't draw much but I'm sure it will add to the electric bill.
