[p]I wanted some pictures, so here we go.[/p][p]
[/p][p]New pretty bedspread, that will keep me covered all night. [/p][p]The "hanging" picture is made with black foam core artboard, $7 from Michaels or $3 from Walmart, for the backing piece. We let the edges show to make a black frame to match our metal. The mats are foam art board, and we did not use a glass cover. Weight is in the 2-3 ounce range. Hung with command strips.[/p][p][/p][p][attachment id="783" thumbnail="1"] [/p][p]
[/p][p]Next is another picture board, same black foam core board, with color coordinated ribbon. Hung again with command stips. Note the carribiner, attached by backing out a screw, and using paracord. Small items hang here. I have a larger carribener that is on the wall, with the showerhead just behind it thru the wall. Again I ran out an existing screw, attached some paracord and resecured the screw. I hang my daypack here. It is only accessible when the slide is out, but does give me some storage on this rather large expansive wall just to the right of the closed bathroom door. [/p][p]
[/p][p]Pictures taken with slide in the traveling position. Pillows left over from her teaching career. [/p][p]
[/p][p][attachment id="784" thumbnail="1"]
[/p][p][/p][p]
[/p][p]Is there not a way to put more than three pics in a post?[/p][p]
[/p][p]Hope you enjoyed our mods. It is a bit more homey and less sterile now.
[/p][p] [/p][p]
[quote source="/post/9887/thread" timestamp="1429897672" author="@ron"][p]
[/p][p]Is there not a way to put more than three pics in a post?[/p][/quote]if you upload them to a free host (photbucket/flickr/etc.) then you can link as many as you want into a single post (you also wont have any size limitations)
